GS1100 swingarm to KZ650 bearing questions
  • z1kzonly
  • z1kzonly's Avatar
Re: GS1100 swingarm to KZ650 bearing questions
30 Nov 2011 03:36
#490792
No eBay APP ID and/or Cert ID defined in Kunena configurationnICE SWINGARM ON EBAY.
  • baldy110
  • baldy110's Avatar
30 Nov 2011 17:44
#490858
OK, I give up.
  • Fritula
  • Fritula's Avatar
  • holly land garage
03 Dec 2011 05:44
#491225
OK what you rely need is factory bearing for pivot axle. Inner diameter is the same so you can use your axle.For spacers on the side of pivot you need to buy two bigger nylon washers.One each side and sand it with sand paper till fits snugly.Nylon does not skweek or makes any noice. I did it same way on my KZ long ago and works perfect.Hope it helps
