Swingarm extention basics
- T_Dub
Re: Swingarm extention basics
13 Nov 2011 20:41
Cool. I've been wondering about it for a while. I guess it'd be nice to do some welding and do some tests.
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
-810cc
-Mikuni RS34's
-GPR Muffler
- wireman
13 Nov 2011 22:10
looks much better without that big ol ugly stock brace on top of it!
- rslingshot
14 Nov 2011 10:25wireman wrote: looks much better without that big ol ugly stock brace on top of it!![]()
Ya it does look alot better with the top brace gone, But the reason I did the busa arm is because they fit the kz frame with nothing more than some pivot bolt reducer bushings. Pretty much all of the early model gsx-r's and all of the busa arms even the second gen busa fit the kz frames with just a simple bushing set up. It is a little more work with other late model sportbike arms.
- hal0tw0
14 Nov 2011 12:00
Good stuff man! we all appreciate your time to document this info.
1976 KA900. VM28 pumper carbs, K&N pod fiters, RC performace 4/1 exhaust, Dyna ignition, Accel coils and wires, Ohlins rear shocks.....more to come
The following user(s) said Thank You: rslingshot
14 Nov 2011 13:41
thanks alot for that little tutorial mike. :evil:
very much appreciated.
documenting does add to the time.
i have not had my hands on a busa swinger,YET :woohoo: .
but now that you have explained it so thoroughly i will be lookin for one to mod.
so is the first gen's (1999-2007) the best for modding for a kz?
- rslingshot
14 Nov 2011 14:51531blackbanshee wrote: thanks alot for that little tutorial mike. :evil:
Thanks Leon. Ya the arm I did was a first gen 99-07 but the second gen busa arms are just about the same, the only real difference is gen 2 has smaller dog bone linkage bearings,instead of a brake bar for the rear caliper it uses a brake block on the inside of the arm and the caliper braket slips into it and the inside of the tubing when you cut the adjuster blocks off there is a webbing inside the arm where the first gen is hallow. Both are good for modding to the kz frame!
14 Nov 2011 17:17rslingshot wrote:531blackbanshee wrote: thanks alot for that little tutorial mike. :evil:
thanks mike.
do you mind telling what you charge for one like this?
if you don't wanna post it i understand,no sweat.
- hal0tw0
14 Nov 2011 19:05
how long is the stock busa swingarm?
- rslingshot
14 Nov 2011 20:03
No I dont mind posting it Leon.
Standard extended swingarm with extended brake bar or new caliper brake block is $400.00
Add underbrace. +$75.00
remove top brace + $75.00
- rslingshot
14 Nov 2011 20:05hal0tw0 wrote: how long is the stock busa swingarm?
A stock busa arm is 22.5 inches from center of the pivot tube to the center of the axle adjuster slot.
15 Nov 2011 10:52rslingshot wrote: No I dont mind posting it Leon.
that is a screaming deal :woohoo: !
thanks for posting mike.
- mark1122
- Keep twisting it
18 Nov 2011 17:04
well done Mike.
Its always cool to see how its done.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
