front steering lock
- 94yj
front steering lock
16 May 2006 11:24
how do i get the steering shaft lock to work all i can get it to do when i put the key in is about 1/4 turn counterclockwise tell me where i am messing up i would like it to lock as it did when it was new
1980 kz 650 ltd
thanks
Post edited by: 94yj, at: 2006/05/16 15:59
1980 kz 650 ltd
thanks
- ABR
- Z1R rider
Re: front steering lock
16 May 2006 14:13
if it's the same as mine, turn CCW 1/4 turn, push in (with steering head at correct angle), turn CW 1/4, remove key.
1978 KZ1000, Z1R
1999 250 Ninja race bike
- ltdrider
16 May 2006 14:24
Mine's never worked.
After about 10 minutes, I gave up trying. With my luck, I'd get it to lock, then guess what?
'76 KZ900 LTD (Blaze)
'96 Voyager XII (Dark Star)
Greensboro, NC
Greensboro, NC
- 94yj
16 May 2006 17:48
which is the correct angle to get it to lock also is it possible to remove the key cylinder assy and clean it up
thanks
thanks
- Sandy
- Fly High,Tony
16 May 2006 18:41
I know on My 77 1000,I can remove it.It's only held in place by a set-screw.I bought a new one from the dealer a few years back,and it was a simple install.
Not sure on the 650,but again...on My 77 1000,I have to have the front end turned all the way,either direction before the lock pin will pass by the steering stopper.
1977 KZ1000 A-1
- btchalice
16 May 2006 18:41
usually full left
Terry Meyer / Wichita KS
76 kz900 w/1000 motor TWZTD
- Biquetoast
- King Jeremy The Wicked
16 May 2006 19:31
Z1R rider wrote:
I second this.
It's a "feel" thing.
You have to have the stem turned in just the right spot, the push-in at just the right time, while you ease the key to turn....
I second this.
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
kz750twins.com
- OKC_Kent
16 May 2006 20:32
Mine only works with forks full right. Turn the key a bit, push in, turn again.
Cashion, OK
78 KZ650 B2 85,000+ miles
- donthekawguy
16 May 2006 21:58
Is it the kind that locks on the bottom or on the side of the neck? If it's the neck the "lock" part fits into a slot on the stem. It might take some time to find the slot by moving the handlebars back and forth.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- Nevco48
17 May 2006 04:48
What ever you do, if you lock it, don't forget to un-lock it before you take off!
- Leather
