This rear reservoir had two screws under a clear plastic piece that you can see to the right of the reservoir cap. Once I carefully pulled that out of the reservoir, I could unscrew it from the metal body and get at the o-ring.
I'm still bleeding the air out of the system. I think the air in there is still pushing fluid out through the seals overnight.
