Help with rear brake!
  • Kzbatty
  • Kzbatty's Avatar Topic Author
Re: Help with rear brake!
15 May 2006 08:53
#47401
Wish I had some measurments off of the kz1000 setup.
Post edited by: Kzbatty, at: 2006/05/15 11:54
  • waterman
  • waterman's Avatar
15 May 2006 08:56
#47402
I think that I can help on that. I'll go home at lunch time and measure...what do you wnat me to measure?
  • Kzbatty
15 May 2006 09:02
#47404
Mostly the bolt hole spacing and the stabilizing rod length.
Thanks!!!!!
Post edited by: Kzbatty, at: 2006/05/15 12:03
  • waterman
  • waterman's Avatar
15 May 2006 09:32
#47408
All I did was throw the assembly that I got off of ebay into the trunk of my car (no stabilizer bar to measure).
Caliper bolts are 3-3/4" c-to-c
closest caliper bolt is 1-1/4" c-to-c from the stabilizer bar bolt
stailizer bolt hole is 6-1/4" c-to-c from the center of the hole for the axle.
It looks as though you need the unit that the calipers ride on, since the pads sit on that unit, not the caliper.
If you need any more measurements than that, let me know.
  • Kzbatty
15 May 2006 14:02
#47470
Well, I can't find a part number for the brake stay. I guess it is just included in the assembly as the picture does not give it a number.
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
15 May 2006 18:52
#47548
Lets start off with getting the o.d. of the axle on that bike.Maybe a 1000 caliper will bolt on,depending on the size of the brake rotor(next thing to check)...then We have to compare one caliper to the other,to see about the brakeline(mounting position)...
SO...Who's got an O.D. measurement on the axle for that bike?B)
1977 KZ1000 A-1
  • waterman
  • waterman's Avatar
16 May 2006 05:40
#47660
Based on your description of what went wrong, do you need the caliper or the unit (the only un-numbered one in the drawing you provided) that the caliper attaches to? Might be a good time to pull it apart to check. I'll get you the diameter for a 1982 LTD1000.
