Brake bleeding tips
- draboo
- zzz
Brake bleeding tips
18 Aug 2011 22:58 - 18 Aug 2011 22:58
I found these tips very informative. I will be bleeding my brake system possibly Monday and I m thinking of trying the reverse bleeding procedure found on this web page:
www.helusa.com/brake-doctor/index.php.57.html
I read a tread about someone who could not get the air out of his system no matter how he tried. I'm speculating that this reverse bleeding procedure will alleviate this problem. My wife already ok-ed the procurement of her turkey baster! She DOES love me! :woohoo:
1983 KZ1100D Spectre shaft
Last edit: 18 Aug 2011 22:58 by draboo.
- KZ_Rage
- Kentucky Bourbon Barrel Ale
Re: Brake bleeding tips
18 Aug 2011 23:03
I use this:
Vacuum Bleeder
works great, just keep refilling the master until all you get is clean fluid in the trap and all is good, no bubbles in my system, If you still have the stock splitter then you might want to take it loose from the tree and move it into different positions while bleeding to make sure there are no bubbles in there.
Vacuum Bleeder
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
2006 ZG1000A6F (Totaled)
2001 ZRX1200R (Sold)
1984 KZ550F2 SOLD!
- loudhvx
18 Aug 2011 23:05
If the front brakes are giving me trouble with bleeding, I set up the bike next to a table, take the calipers off (with hoses still connected), put a piece of wood between each set of pads, then bleed the brakes with the calipers on the table. It's more comfortable, and the air moves horizontally, rather than down, so the airbubbles don't keep working their way toward the master.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- draboo
- zzz
19 Aug 2011 02:23
I don't have one of those bleeders and cannot really justify purchasing one to bleed brakes one time. I ll check and maybe a neighbor may have one. Lots of farmers around where I m renting.
Thanks for the tips! I still do have the stock junction block between the forks. I m having my new lines made locally. I thought about eliminating the junction, but decided to keep things stock.
- mark1122
- Keep twisting it
19 Aug 2011 17:01
i thing to remember if u are having trouble.
u can remove any part that looks like it may trap air ,and try to position it in a manor that will allow the air to escape.
the new radial masters have a bleed nipple on top for this reason. this is a spot that is prone to trapping air. also on the calipers, some models dont have the bleed nipple on the highest part, so air can be trapped above the nipple.
i use a Vacuum Bleeder
as well. it saves u a lot of frustrasion for 50 bucks. and u realy should change the fluid every couple of years.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- draboo
- zzz
19 Aug 2011 22:20mark1122 wrote: i thing to remember if u are having trouble.
I'm thinking I just might pick one up. I was gonna try to reverse bleed it like it says on that web page I posted(very last hint on the page).
- Old Man Rock
20 Aug 2011 09:40
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- havakaw
20 Aug 2011 22:57
The biggest PITA with these calipers,is that the bleeders are not at a 12 o'clock position.They are off to the side a bit.You CAN"T get the air out of them without the bleeders straight up and down.I've used a big pair of Channel-Locks to hold the piston back a bit,while the wife squeeses the brake lever,and I open the bleeder to work the air out of each side.It helps to "Gravity bleed" each one first,and then work the lever untill the feel is good.But yeah,the bleeder HAS to be straight up to fill behind the piston,or you will never get the air out.
'80 KZ 750 LTD-H
'82 KZ 1100 A-2 Shafty (ex-bagger)
- fxdl2051
02 Sep 2011 04:31
I just had a chance to use a little piston suction brake bleeder gismo I bought a while back, think it was from Harbor Freight. Works great, it basically siphons brake fluid out of the line, without pumping the brake lever. I'll see how it works when the front brakes are rebuilt but a quick trial session was very promising.
Last edit: 22 Jan 2013 04:35 by martin_csr.
- Turtle
02 Sep 2011 10:17
Before I purchased a vacuum pump, I used a small household oil can you can get at any hardware store and reverse filled through the break caliper.
I think the biggest issue with motorcycle brakes is the master cylinder does not move very much fluid, and this is why it can take a very long time to bleed the traditional way.
1980 KZ 1000 A4 with 750 Zephyr swing arm and ZX-9 rear wheel
- Kidkawie
- I bleed premix
02 Sep 2011 16:31
Gravity bleed.
Open bleeder, slowly apply brake, close bleeder, let off brake, repeat.
Works every time.
Works every time.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
