squishy forks
- KZ_Rage
- Kentucky Bourbon Barrel Ale
Re: squishy forks
10 Aug 2011 17:52
You can use schedule 40 PVC, that is what you get in the Progressive Springs box for a spacer from the factory, with mine I'm pretty sure it even said for me to cut an inch off each one for my bike.
The ones I got weren't even cut squared off on the ends so I did some up in a lathe real quick and used those instead.
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
2006 ZG1000A6F (Totaled)
2001 ZRX1200R (Sold)
1984 KZ550F2 SOLD!
- pburnhamb
Re: squishy forks
10 Aug 2011 18:21
schedule 40PVC, ok. i will do this and report back! thank you
1978 kz650b (810, 750 head)
1976 kz900
1977 xs650
1976 kz900
1977 xs650
Last edit: 22 Jan 2013 03:20 by martin_csr.
- Medina
Re: squishy forks
28 Jul 2012 08:33martin_csr wrote:The "specified" comment was in regards to the 81 KZ650 - as mentioned in the reply. And the info is from the genuine Kawasaki factory service manual - it says to use SAE 10W (pg 2-21 Table 2-12).650ed wrote:martin_csr wrote: You can get some Progressive springs. I've seen fork springs at Z1Enterprises.com but can't seem to locate them.
If you get new springs, it might be a good idea to upgrade the rear shock absorbers as well. Otherwise, you may end up with a firm front end & a mushy rear.
I rebuilt the forks on my 81 650 & used the specified 10W fork oil. The springs were well within the service limit. I'll use 15W next time, but the bike probably needs a suspension upgrade.
I read this and thought - I just checked the genuine Kawasaki KZ650 manual this morning and verified that it specified 15W fork oil before posting my answer in this thread, so why would Martin say "specified 10W fork oil?" Was he using a Clymer or Haynes manual? Then I though - just for once, before I shoot my big mouth off disputing someone's information let me do a bit more research. Here's what I found. The Kawasaki KZ650 manuals are all over the place regarding the fork oil weight. In them I found multiple places where SAE 10W; SAE 10W20; and SAE 15W were specified. So Martin's assertion of "specified" is also true. Personally, I've always used 15W Bel Ray fork oil and have been very please with the results. EdNext time I'm using 15W.
I'm thinking my forks dive a bit too much inspite of the fact I put progressives and 10w in there.
I bumped this thread as my manual, a shop manul, but oddly the whole thing is in metric, and constantly having to convert, says 10W also
I'm running a windjammer, should I skip right to 20w?
thanks
1981 KZ1100 Vetter "Luminous Navy Blue" DAMN YOU COLOR CODES!
Medina, Oh
My Bike Thread
www.kzrider.com/forum/10-new-members/469298-from-ohio
Medina, Oh
My Bike Thread
Re: squishy forks
28 Jul 2012 10:42
You could go right to 20w or you could give the 15w a try. Either way, if you use Bel-Ray, you can mix the different weight fork oils to fine tune the ride. So if you found 15w wasn't stiff enough and 20w was too stiff you could mix half of each and tune the ride someplace in the middle of the two. Ed
- Motor Head
Re: squishy forks
28 Jul 2012 10:47
Might need a couple of things with running the Vetter. First how much pre-load is there on the springs. When the bikes front end is all the way up, full fork extension, how much do you measure for distance for the fork cap to tighten down on the spring? An additional 1/2- 3/4" here might help alot. I use about spacers cut to about 3 1/4" on mine, so the springs and spacers are level with the top of the Tubes. Also I run 15w fork oil, but it is a different model. Its the 82 KZ 1000 LTD with 38mm forks, Vetter also.
I also just put in Race Tech Emulators, with Progressive Springs, and a Fast from the Past Fork Brace. Its a whole different front end.
- wireman
Re: squishy forks
28 Jul 2012 13:07
Try some 10/30 0r 10/40 synthetic motor oil in there in place of that 10w
