shock poll
16 Jul 2011 09:50 #463133 by markthink
shock poll was created by markthink
Hi folks.. getting to shocks on the KZ1100 LTD. Going to ride mostly one up (260 lbs) with some gear this year. Found about a $45 differece between new Progressive 416 air shocks and the 12 series with appropriate springs.
I'd anticipate air as cushier and adjustable but spring as a sportier ride. Frankly thinking if I go air an don't like it resale would be better on the 416 than the 12.
Quick poll: what's your preference, air or spring for this size bike?
'83 KZ1100-A3 Shaft, Vetters
  • hocbj23
  • Visitor
16 Jul 2011 10:32 #463137 by hocbj23
Replied by hocbj23 on topic shock poll
KZ 1000 CSR -one up mostly-185 pounds-Hagon shocks spring only no air.They can spring it any way u want it.bj
16 Jul 2011 16:59 #463186 by dejavoodo41
Replied by dejavoodo41 on topic shock poll
I'm running the progressives from Z1E with the 105/150 springs and am pleased with the ride from them.
1977 KZ1000A With 1980 KZ1000A MKII engine, Wiseco 1105 kit, Dyna S Ignition, 3 Ohm Dyna Coils, Cams, Mikuni RS34 Carbs, Vance and Hines Pro Pipe with Comp Baffle
New Smyrna Beach, FL
16 Jul 2011 22:00 #463229 by Nebr_Rex
Replied by Nebr_Rex on topic shock poll
Air shocks?
Ever have air shocks on a car?
Ever cut the air line for those air shocks?
Do your self a favor and use hyd. shocks with a spring.
Springs are adjustable, preload can be added for heavier loads.
Air gets very stiff when compessed.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
17 Jul 2011 18:30 - 17 Jul 2011 18:34 #463377 by steell
Replied by steell on topic shock poll
Nebr_Rex wrote: Air shocks?
Um, air shocks "are" hydraulic shocks, they just have a sealed chamber that can be pressurized.
When air shocks lose their air pressure they just become ordinary hydraulic shocks.
As far as air getting very stiff when compressed, so does most everything else :)
Air will give you a lot softer stop when bottoming a fork than a coil bound spring will.
"Springs are adjustable, preload can be added for heavier loads."
Um, no, preload simply adjusts ride height (or sag). If you're a 250 lb guy and you buy a bike sprung for a 150 lb guy, you best be replacing the springs.
Last edit: 17 Jul 2011 18:34 by steell.
17 Jul 2011 23:27 - 17 Jul 2011 23:42 #463423 by Nebr_Rex
(((How about on a shock where the shaft bottoms out before the spring?)))
(((Um yes, it's done in racing all the time.)))
I will have to disagree with you on those 2 points.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
Last edit: 17 Jul 2011 23:42 by Nebr_Rex.
18 Jul 2011 00:35 #463435 by 650ed
Replied by 650ed on topic shock poll
"Um, air shocks "are" hydraulic shocks, they just have a sealed chamber that can be pressurized.
When air shocks lose their air pressure they just become ordinary hydraulic shocks."
There's truth in this, but motorcycles with ordinary hydraulic shocks have springs to keep the bike up. On air shocks that have no springs the air is intended to serve as the "springs." If they lose their air pressure, the air shocks will collapse to their compressed position and there will be nothing to lift the bike up to its normal ride height. I'm no lover or hater of air shocks, and I've never used them on a bike. I suspect they work fine and are designed not to leak the air just as regular shocks are designed not to leak the hydraulic fluid. I use Hagons and have used S&W shocks in the past; these are both outstanding shocks though the S&W's are no longer available (maybe bought out by Progressive?). The only poor shocks I've used were those that were original equipment on the bikes I've owned. Ed
20 Jul 2011 00:25 - 20 Jul 2011 00:26 #463856 by MkII
Replied by MkII on topic shock poll
"pre-load adj. ride height and sag." quoted Steel
not exactly. setting static and rider sag is first accomplished with correct value springs for the weight of the bike (static)or a fully kitted rider (rider sag)then tweaked with pre-load to a certain extent for rider preferred feel while only using up a certain amount of spring doing so.
Ride height is a totally diff exercise adj. via shock or chassis linkage ala Ducati and or adjustability ala top shelf Ohlins for ex. The front end is adj. by sliding the tubes up or down to accomplish a desired front end height.
your basic info is sound but pre-load has nothing to do with ride height. ride height is a chassis/geometry adjustment not a suspension adj. this fact is one often assumed or confusing to folks and it makes suspension guys twitch.
1977A1 current project: 1075, Web cams, VM29's Cavanaugh massaged head, Z1 crank
1979A3A Parked in 1986 left in shed
Phx,Az
Last edit: 20 Jul 2011 00:26 by MkII.
20 Jul 2011 01:08 - 20 Jul 2011 02:29 #463867 by steell
Dang, see what I get for reading Tony Foale and Kevin Cameron? I really ought to know better than to trust anything they say.
But for anyone reading who is not the worlds foremost suspension expert, and would like to learn about setting up their suspension, I suggest Kevin Cameron's book "Sportbike Performance", and especially chapter 13, "Suspension Tuning".
Read above, if you don't see your mistake then I suggest a bit more studying is in order.
Argue with Kevin Cameron, I just double checked "Sportbike Performance" chapter 13, and Kevin Cameron says I'm correct. Is that good enough, or do I have to dig out Phil Irving?
No problem, you have every right to be wrong :laugh:
Last edit: 20 Jul 2011 02:29 by steell.
20 Jul 2011 03:02 #463883 by Nebr_Rex
And so do you.:whistle:
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
  • KZ_Rage
  • Kentucky Bourbon Barrel Ale
20 Jul 2011 10:56 #463927 by KZ_Rage
Replied by KZ_Rage on topic shock poll
Wow! I've seen oil wars, tire wars, pod/air box wars, gasoline wars... but this is a first! :lol:
Not joining in this one, nope... not gonna, just going to say to the OP, get a set of progressives and be happy! ;)
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
2006 ZG1000A6F (Totaled)
2001 ZRX1200R (Sold)
20 Jul 2011 11:15 - 20 Jul 2011 11:18 #463934 by steell
Yeah, but you see I can site my sources, the best known suspension and frame experts in the world (Tony Foale being in the UK and Kevin Camaron in the US), so it's them you're saying are wrong.
Are you really sure you want to proclaim yourself the worlds foremost expert on motorcycle suspension?
Or is it maybe possible you mis-heard something somewhere and are now staking everything on it?
Do you really expect me to address every possible type of shock absorber, or you just wanting to argue? How about friction shocks? Or maybe magnetic shocks? Or even within hydraulic shocks you have fixed orifice versus variable orifice, and several types of that.
KZ_Rage, can't argue with the Progressives, although some people might, I have Progressive fork springs on my daily rider 750 twin and on my ZX11, Racetech Gold Valve emulators and linear springs in GSX750 forks on my 750 twin project. Progressive may not be great on the track, but I love them for every day street use. The Gold Valve emulators are pretty cool also, I am rebuilding my spare ZX11 shock with the Gold Valve emulator and a Racetech straight weight spring.
Last edit: 20 Jul 2011 11:18 by steell.
