1976 KZ1000a wire spoke wheels to alum. wheels???
  • Highlander
  • Highlander's Avatar Topic Author
Re: 1976 KZ1000a wire spoke wheels to alum. wheels???
01 Jul 2011 09:28
#460436
Hey Stuart, clean looking KZ you got man!!!! Wish mine looked half that good. Mine appears to have been rode hard and put up wet.
Wish I was in Scotland also. Best I can tell that is the Motherland for me and my ancestors since I come from a long line of Campbells originating from Scotland.
I live in Alabama, USA so its a pretty good little trip to your location. Plan to make the trip one day though for sure.
My KZ1000 is also a 77, with factory wire spoke rims, but it also has rear disc setup already on it and looks to be the factory set up. Hopefully, I can get some pics of my bike posted up on here in the very near future, but right now its apart due to carbs, rust in gas tank, and a new Paint Job on the tank and plastics upcoming.
I got to do something about the wire spoke wheels though, they are rusted and the chrome is already flaking off really badly. Dont think they can be salvaged. Thats why I was wanting input on how to go to the Mag wheels and what all is involved.
  • Russ Jackson
  • Russ Jackson's Avatar
02 Jul 2011 13:15 - 02 Jul 2011 13:22
#460642
I am partial to the Lesters myself...Russ
1976 KZ 900 B1 29 smoothbores, Kerker, Lester Mags
2008 Kawasaki Concours 14 abs
Last edit: 02 Jul 2011 13:22 by Russ Jackson.
  • Sactown900
  • Sactown900's Avatar
06 Jul 2011 16:45
#461368
Sorry not to better answer the question, but here's an "option" from Redline:
redlinecycle.com/Mvc-041F%20Wheel%20Options.html
My PO put a slightly larger back tire on a 3.5 rim, so I am staying with spokes. My front is beyond hope, so I will find a used 76 KZ900 front spoke rim or go brand new from someone like Redlinecycle.
My front spokes have more rust than chrome.
  • Gatty
  • Gatty's Avatar
09 Jul 2011 00:23
#461797
I have the reverse problem as Highlander. I have mag wheels on my '77 and I am putting spoke wheels on it. Only problem is that some parts, mainly the collars, are different from mag to spoke. Highlander, I think you will have the same problem as me when you get the mags. I would be willing to swap the required parts with you if you are interested. If not, does anybody else have, or know where I can get these parts.
I require the following parts for rear spoke wheel parts PN's - 42032070 Rear Collar, 42036024 Sleeve, 42010030 Collar BRG, and for the front wheel 41039028 Collar BRG. I am desperate to get these parts ASAP and will make itvery worth while to anyone who can supply me with these.
See attached file of my baby below.
  • steell
  • steell's Avatar
12 Jul 2011 01:29 - 12 Jul 2011 01:30
#462389
I may have all but the first one (42032070 Rear Collar), since I just checked and the KZ750B twin uses the same parts.
If you want to come here and dig through my parts till you find them, I'll give them to you :P
Zip 47338
Last edit: 12 Jul 2011 01:30 by steell.
  • Gatty
  • Gatty's Avatar
12 Jul 2011 05:06
#462403
Thanks all the same steell. Another generous soul has agrred to supply me with all the parts I need.
Cheers again.
  • Highlander
12 Jul 2011 09:42
#462423
Thanks for all the advice guys. I think after I have digested all the differences, I am going to just try to find some replacement spoke rims and keep the bike as close to original as possible.
I think this will be a much easier option for me, and save a whole lot of conversion time.
Do they make a back spoke chrome rim that will hold a larger tire than stock, and will I need to go to a different swing arm to accomodate the larger width tire?
  • smokey
  • smokey's Avatar
20 Jul 2011 11:02
#463930
Hi Highlander, I am chasing a spoked wheel hub off a a1 kz1000. Are you looking to sell it if you go ahead with you conversion. Cheers Kim
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
20 Jul 2011 13:30
#463959
Highlander wrote: Do they make a back spoke chrome rim that will hold a larger tire than stock?
Count your spokes, should be 40 IIRC, then go to Ebay and search something like this: 18" rim 40
shop.ebay.com/Motorcycle-Parts-/10063/i....trksid=p3286.c0.m282
Or whatever rim diameter you're using.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
