center stand spring
  • Rocky
  • Rocky's Avatar Topic Author
center stand spring
20 May 2011 15:24
#452412
Hi i put a spring on my center stand and now when is on the upright position it pushes up on my chain.i bought from a motorcycle shop that works on kz,s i know he gave me the right spring.does anybody have any ideas or suggestions to fix the problem.i have a 1976 kz900a.thanks!!!
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
Re: center stand spring
20 May 2011 15:28 - 21 May 2011 11:39
#452413
The easiest fix is to bend a "L" shaped piece of metal and drill a hole in it and bolt it to the passenger foot peg. Roy
Last edit: 21 May 2011 11:39 by roy-b-boy-b.
  • Rocky
20 May 2011 15:34
#452415
thanks i will do that.
  • z1kzonly
  • z1kzonly's Avatar
20 May 2011 16:11
#452423
When it was stock, it hit the bottom exhaust pipe. It had a rubber grommet.
  • Proxy
  • Proxy's Avatar
  • 80% Human 20% Nuts/Bolts
20 May 2011 19:16
#452456
My father showed me a trick when putting on the spring. Put the spring in a vice and rock the spring back and fourth slipping pennies between the coils until the spring is long enough to put over both holders. Then using vice grips pull the pennies out of the coils. Worked like a charm. Sorry for the hijack. Just thought it was neat and would have never thought of it. Back to the movie! ;)
Take it from me cuz I found
If you leave it then somebody else is bound,
To find that treasure, that moment of pleasure,
When yours, it could have been.
1977 KZ650 B1 Being restored to original (Green)
1977 KZ650 B1 Original (Red) Sold
1977 KZ650 B1 Donor Bike for Parts
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
20 May 2011 19:28
#452460
Just get rid of it.
You can slide it up under the bike and throw a rod through the holes when you need to use it in the garage or whatever.
Shed some pounds! :laugh:
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • fordtruck
  • fordtruck's Avatar
21 May 2011 02:29
#452516
Proxy wrote: My father showed me a trick when putting on the spring. Put the spring in a vice and rock the spring back and fourth slipping pennies between the coils until the spring is long enough to put over both holders. Then using vice grips pull the pennies out of the coils. Worked like a charm. Sorry for the hijack. Just thought it was neat and would have never thought of it. Back to the movie! ;)
Never thought of doing that! I'll definitely remember this one. Thanks for posting this!
'77 KZ1000-MTC 1075 kit. Stage 1 port
  • peter1958
  • peter1958's Avatar
  • OneShoe50
  • OneShoe50's Avatar
  • 10-4? 10-4!
21 May 2011 09:54
#452541
TeK9iNe wrote: Just get rid of it.
B)
+1 weight reduction FTW!
77 KZ1000A1 - Under going a psuedo ELR overhaul
79 KE175 (gone)
81 KZ550A2 (gone)
81 KZ750E (gone)
Sure it looks OK now, but wait until I really make it pretty, with some chrome and paint and some new tires and grips and the wiring. Don't forget the gearing, and the LED's and, and, and....
  • Proxy
  • Proxy's Avatar
21 May 2011 10:28
#452546
Plug and play center stands are OK for sure and to those looking to make it light they are a bonus but a center stand is certainly a handy thing. Had a plug and play on a 900 LTD for a little while and more than once grumbled at having to get down there and plug it in. Yeppers! Just a lazyass comment but when it's 90+ out and I want to lube or clean a chain or check my back tire out or put air in the tire they make it a lot easier. I don't much care for bikes without center stands or kick starters. It's just me.
  • dshelly
  • dshelly's Avatar
21 May 2011 10:57
#452547
Just FYI your 900ltd didn't come from the factory with center stand brackets. If it were a true 900ltd frame someone must have added the brackets.
Occupation:Machinist 25+ exp.
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
  • roy-b-boy-b
21 May 2011 11:41
#452556
I do believe the brackets were on there from the factory. Roy
