my streefighter done!
- sbjones
Re: my streefighter done!
02 May 2006 23:43
yes please, more pics and specs. like what kind of carbs and jetting size, exhaust and things like that.
thanks.
oh by the way looks great!!!!
thanks.
- rattler
04 May 2006 21:39
thamks all...
the paint is still the same as it was , it is actualy not black. it a real dark jade green with pearl. it dose look black at night though, till you get up on it.
the complete front end is from a 2006 kawasaki zzr1200 ninja. forks, wheel, fender, brackes, tree, controls, ect. i hooke up my two-step into one of my control swithces. it wasnt a bolt on and take off swap. hade got lucky and found a guy near hear that dose a lot of machine work on the side at a steal. he done the hat-bushings i needed to press into my tripples to make my steering stem swap out. it has a six over swingarm. rear fender has been moved back. 5.5 back wheel with a 180 back tire but will be getting a new 190 after i burn this one off at derby this weekend.
the motor is pretty much the same as it was. i was on a poor mans budget. its a wisco 1075, welded crank, 34cv carbs, vance hines 4-1 header( upswept not pro pipe. it sets 2.5 inches from the ground :silly:) dyna coils, dyna wires, dyna s ignition, dyna drl-400 two step.
i will try to take better pics this weekend at derby. wont be able to post any pics till i can get to my old ladys moms pc. my usb ports are screwed.
