best fork swap for 82 kz1000
- bdydrppup
17 Jan 2011 04:20
i just bought a 1982 kz1000 and love it and plan on modding the chassis and have been looking on e bay for a set of usd forks to use. i was wondering which is the simplest swap? least amount/no machineing? thanks in advance
- hocbj23
Re: best fork swap for 82 kz1000
17 Jan 2011 05:55
what kind of chassis mods?what is the problem with stock forks?what are u going to use the bike for?simple is not always best if u have a specific type of riding u are going to do.bj
- bdydrppup
17 Jan 2011 06:15
I will prob do a rear swap also. I will only use it for street riding and I mainly want to do it for looks and to have more moddern brakes ect. I can cut and weld all day and fabricate I just don't have access to machine shop tools. Lathe ect.
- daskraut
17 Jan 2011 06:26
which model KZ1000 do you have?, if it is a CSR or an LTD than a GPZ1100 front end would be an upgrade. There is a huge difference between a leading axle front end and a standard. I just used Progressive springs in my GPZ forks and a Daytona fork brace, works great. If you have to have inverted forks, then check out the english "street fighter" scene, they love KZs and mod them beyond belief!.
When in doubt, GAS IT!!
- testarossa
17 Jan 2011 06:58
I found my 1995 GSXR 750 forks to be a fairly easy swap. They are among the longer USD forks available. I believe that ZX-9 forks are the longest.
Here's the link to my build thread if it helps: kzrider.com/index.php?option=com_kunena&...w&catid=11&id=340793
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
- porchev914
17 Jan 2011 09:00
For simplest bolt on, modern USD forks, and you don't mind spending the money, then custom triples clamps are the easiest, fastest way to do it. I have a set of custom clamps that I just got from another member here and they are nicely made and mount K5 GSXR1000 forks (05-07 or so)
they bolt up to the Kz frame using Kz bearings with the stock fork offset. The gullwing drop gives you back some of your lost ride hight with the shorter modern forks.
FRANKEN Z!
- bdydrppup
17 Jan 2011 09:51
It a kzt00k. Should be an Ltd. Thank y'all for the info so far.
- trianglelaguna
17 Jan 2011 13:16
you can get a cop bike front end cheap...the whole thing triples and all is what you want to bid on..e-bay.... and search KZ 1000P complete front end...81 -98 and you may even end up with a better front rim and brakes too.....
now if you want a hybrid /modern/upside down fork and complete front end ...then a zx-9 or zx-7 complete front end....
Unless of course you want to spend a few thousand then the sky is the limit
Complete front end estimates
cop bike 81-98 complete front end 200+ 50-75 shipping aprox
ZX7-ZX9..300-600....50-75 shipping
pair of gpz froks and fender that will slide onto your triple tree and mount your wheel brakes ect..
forks 100-150 + 30 shipping
fender 35-70 + 20 shipping
all of these items can probably be found any day on e-bay....
good luck
p.s update your " avatar or sig " with yr and model so folks can follow your builds better,and oh yeah...pics are a must.......
good luck
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- bdydrppup
23 Jan 2011 06:34
i found a great deal on a 92 zx7 conplete front end but im not sure of the length. i know yall said the zx9 is longer. is there a place to find the front end lengths? i will be lowering the bike some so maybe the zx7 would be ok. thanks again guys
- testarossa
23 Jan 2011 06:52
bdydrppup wrote:
Click this link for some pertinent discussion: kzrider.com/index.php?option=com_kunena&...ew&catid=5&id=385938
FWIW I paid $200 shipped for a mint set of 1995 GSXR 750 forks from ebay. Included clamps, clip-ons and the complete axle with speedo drive. All they needed was a set of new fork seals. I feel like I got a little lucky here.
2004 ZX-10R
Angola, IN
2004 ZX-10R
Angola, IN
- bdydrppup
23 Jan 2011 09:46
thanks man! in that thread was a guy with the same92 zx7 front end and it barely shorter than what i have and i picked it up for 130 shipped with both trees, axle, speedo,wheel spacers and bearings. im stoked. now gota figure out if ima keep the factory wheels or change to zx7
- mjg15
23 Jan 2011 13:17
I've been thinking of using 95-97 ZX6R forks with Zephyr 750 triple clamps. They are a more modern cartridge damper fork and the length should be adequate since the clipons on the 6R mount above the triples. They are also fairly inexpensive and plentiful on Ebay.
'80 Z750fx
'81 KZ550A
'81 GPz550's, Too many!
'82 KZ1000R
'82 GPz750
'90 ZR550
Project photo album: s163.photobucket.com/albums/t289/mg15_ph...GPz-ZR550%20project/
s163.photobucket.com/albums/t289/mg15_ph...current=DSC01286.jpg
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
