gs1100 swingarm Q's
- Frankn9
- otakar
Re: gs1100 swingarm Q's
16 Jan 2011 12:40
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
16 Jan 2011 12:41
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
16 Jan 2011 12:45
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Frankn9
16 Jan 2011 12:47
nice, thats a 140 tire? 140 by what? if I may ask.
- otakar
16 Jan 2011 12:55 - 16 Jan 2011 12:57
To be exact, that is an AVON AM21 MT90-16 5.5" wide. My favorite rear tire of all time. It is too bad it is not available in an 18"
EDIT
Also the rim is off of an 1981 LTD
EDIT
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 16 Jan 2011 12:57 by otakar.
- kawasakispeedin
03 May 2011 22:17
hello! i recently purchased a gs1100 swingarm and hope to be doing the swap on my 1980 kz1000ltd in the near future. i see that you had some of the same questions that i have. what pivot bolt did you use and where did you get any spacers you may have used? what axle did you use? did you have to make/buy spacers for the rear wheel? if so where did you get those? was there any modification to the rear brake master cylinder? ive seen a few pictures of bikes with the gs1100 swingarm and the rear brake push-rod looks different like it has been moved or modified? any other tips of suggestions would be greatly appreciated! thank you...
-1980 Kz1000 ltd (current)
-1993 Suzuki GSX600F
-2006 ZZR600 (past)
-1981 GPz550 (past)
-2006 ZZR600 (past)
-1981 GPz550 (past)
- hocbj23
03 May 2011 22:49
I used washers from Ace Hardware as spacers-cheap.Used stock rear master cylinder and brake line. Used an earlier brake torque rod (the flat one) from a KZ so I could lighten it up a tad by drilling "speed holes" in it.Plug and play pretty much.bj
- donthekawguy
04 May 2011 03:40
I used a thin washer and a "regular" thickness washer on each side. They were a snug fit but tapping them in did the trick. i have a 140 tire on it and I think you can get a 150 in it. I lucked out and got the chain gaurd for free when I got my arm and it fits fine. I did have to do some grinding on the brake arm but not a lot.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- kawasakispeedin
04 May 2011 14:32
thank you guys! my swingarm came with everything except the rear axle. i was wonderring what gs1100 sub model i need to look for when i am trying to purchase an axle? ive seen G and GL and i was wonderring if it makes a difference? and what rear shocks are you running? id like to get longer shocks to make up for any drop in the rear with the new swingarm.
-2006 ZZR600 (past)
-1981 GPz550 (past)
-2006 ZZR600 (past)
-1981 GPz550 (past)
- toad
05 May 2011 09:51
14" eye to clevis worked for me.
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
- DoctoRot
29 Jun 2011 05:17
I am trying to do this mod myself and was wondering what some of you used to space out the axle. I have washers for the pivot point, but there is enough room on the axle that I don't want to use washers. The axle I have came with three spacers of some type, I cant seem to figure a combination of them that works.
Could someone put a photo of how they spaced their axle for this?
