Rearsets and Front End Complete !!
- Blake_ae
Re: Rearsets and Front End Complete !!
21 Apr 2006 05:29
How did you drop the gauges down 4 inches? I'd love to do that but have no idea how. Post more pics and a little more detailed explanation please and thanks!
Awesome ride over all. Hell where did you get the rearsets too? They are also on my list...
- 77KZ650
21 Apr 2006 05:35
Man, thats NICE! love it
What kind of mirrors are they?
I would suggest getting a small cafe fender tho (and a 4-1 pipeB) )
fairly new ZX rear sets?
Scott
Scott
07 MDP Rookie of the Year
- Max2022
21 Apr 2006 05:47
Disagree on the pipes, I like the look of it having twins.
But it would look cooler with the fender
- rstnick
21 Apr 2006 06:56
Looks great Henry! Quite the transformation.
And yes more info on how you did it all.
Specifically; What kind of rearsets are they? And how did you mount them? Your original pegs were the single bolt mount, correct? Did you drill and tap two new mounts, or just drilled and bolted through?
Is your shift pattern still one down and 4 up? Can you still use your kick starter.
One more, How is the rear brake light activated?
All you 650 guys check out the 650 info and forum site (link in my signature). And Henry, add these mods there too.
Post edited by: rstnick, at: 2006/04/21 16:12
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- cnyl
21 Apr 2006 07:34
Great looking bike! Nice job. What kind of rear sets are those? Can you post a close up pic of the headlight assembly? Is that pvc between the carbs and airbox?
1982 KZ1000 M2 CSR
North Port, FL
Check out my band
www.myspace.com/tukrhill
North Port, FL
Check out my band
- indykaw77
21 Apr 2006 07:51
Outstanding....you been busy!! Whats the seat off of????
And I'll chime in for more 411 on lowering the gauges as well.....
Kawasaki Motorcycles...because cars lean th wrong way!
- johnny chop
21 Apr 2006 08:25
WOW....what a transformation:woohoo: Great work....
More info on the rear sets & lowering of the bars....JC
- wireman
21 Apr 2006 12:16
gauges are mounted under mounts on top triple tree istead of on top."elephant ears" for headlight are mounted upside down to lower light.
- dutchz
21 Apr 2006 12:58
Hey Henry, looking good. Be careful with that tach cable, I have a similar setup with dropped gauges and a lowered front and the wheel ended up eating my cable under load. Can't tell when it's just sitting.
1974 Kawasaki Z1
Stock front hub and rear axle.
- dutchz
21 Apr 2006 12:58
1974 Kawasaki Z1
- captaincrusty51
21 Apr 2006 13:12
Beautiful transformation. I am biased towards loving black KZ650s
What are you using to connect the carbs to the airbox?
Post edited by: captaincrusty51, at: 2006/04/21 16:14
1978 KZ650C
Keihin CR Special carbs, MAC 4 into 1, Koni Shocks, Emgo Pods
2002 ZRX1200R
Akrapovic exhaust, Teds Ignition Advance, Steering Damper, Dunlop Qualifier tires, Corbin GF/L,Rear tire hugger, Tsukigi braces
2002 ZRX1200R
- OKC_Kent
21 Apr 2006 14:25
captaincrusty51 wrote:
It looks like PVC.
By the way it is beautiful, great job!
What are you using to connect the carbs to the airbox?<br><br>Post edited by: captaincrusty51, at: 2006/04/21 16:14
It looks like PVC.
Cashion, OK
78 KZ650 B2 85,000+ miles
