1982 kz750 csr twin centerstand
  • jeremysmith035
  • jeremysmith035's Avatar
Re: 1982 kz750 csr twin centerstand
27 Jan 2020 16:38
#818059
i know this is an old thread but if you (or anyone else) found a solution to your center stand issue it would be helpful
  • martin_csr
  • martin_csr's Avatar
28 Jan 2020 05:55 - 28 Jan 2020 08:41
#818081
You'd either have to weld center stand brackets to the frame or get a frame from a later 750 Twin. The diagrams at partzilla show that the 83-84 K1/K2 Ltd Belt models had a center stand. Those frames are probably otherwise virtually identical to the 750-CSR. If you go the welding route, then a center stand from a 750K is probably the best match.
For around the garage you could buy or make a portable main stand. Years ago I saw one that was maybe a 2x10 w an iron pipe handle.
You could do an internet image search for homemade motorcycle center stand or something like that. There are probably youtube videos.
Last edit: 28 Jan 2020 08:41 by martin_csr.
