Disc Brake Squeal Fix .... Good, and Not So Good
  • seanof30306
  • seanof30306's Avatar Topic Author
27 Sep 2010 20:39
#402359
So, I replaced the pads on my '79 KZ650 awhile back, and they've squealed ever since.
I've had the pads off and sanded them, but no good.
On this week's MotorWeek, Pat Goss talked about a spray disc brake squeal fix, so whe I was riding today being very annoyed by that squealing, I stopped at an O'Reilly's I was passing and bought this:
www.oreillyauto.com/site/c/detail/PTX0/8...?keyword=anti-squeal
I sprayed it on right there in the parking lot. Rode the bike slowly and hit the brakes 8-10 times as the instructions recommended (I actually read them).
On the plus side, the squeal is gone. Totally and completely.
There is, though, one slight downside.
This shit is silver paint! I thought the silvering on the wheels and tires as I sprayed it was just the stuff making them wet, but when I got home, I noticed silver "paint", or whatever this stuff is, all over my hands.
I freaked, grabbed a rag, and started furiously rubbing on the wheels and tires. It partly came off the tires, but it didn't budge on the wheels!
I re-read the directions on the can, but it says nothing about this.
Does anyone know how to get this stuff off?
"That @#$%!!! KZ650"
79 KZ650 B3
Dual front disc brakes
Z1R 18" front wheel
Pumper carbs w/pods
MAC 4-1 w/ drilled-out baffle
Dyna S ignition w/ Dyna Green coils
WG coil mod
'81 CSR charging system
17/41 gearing
  • MFolks
  • MFolks's Avatar
Re: Disc Brake Squeal Fix .... Good, and Not So Good
27 Sep 2010 21:07
#402362
Possibly Acetone will remove it, MEK should (but use it in a well ventilated area and wear slovent resistant gloves).
Some riders have used the silver anti seize on the back of the pucks to dampen the noise.
  • seanof30306
27 Sep 2010 21:39
#402367
Thanks for the advice.
What is MEK?
Also, the directions say to spray it directly on the rotor.
Sigh .......
At least the brakes don't squeal anymore.
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
  • MFolks
  • MFolks's Avatar
27 Sep 2010 21:51
#402371
MEK, Methyl Ethyl Ketone(SP) a strong solvent, will cause severe health problems if absorbed or inhaled:
www.jtbaker.com/msds/englishhtml/m4628.htm
  • seanof30306
27 Sep 2010 21:56
#402374
Wouldn't something that strong also take the finish that's already on the wheels off?
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
  • MFolks
  • MFolks's Avatar
27 Sep 2010 22:21
#402376
It might,if the wheels are either powder coated or painted. If it were me, I'd try first some 70% rubbing Alcohol, and then use the higher strength Alcohol(something like 90%, I think). Paint thinner might remove it too.
Be careful and use gloves outdoors, as most solvent fumes are easy to catch on fire.
  • seanof30306
27 Sep 2010 22:29
#402377
Well, they're the factory aluminum rims, with the black finish. I'm sure they're not powdercoated, so I'm guessing it's paint.
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
  • bountyhunter
  • bountyhunter's Avatar
27 Sep 2010 23:00
#402382
Try mineral spirits first in case the silver is some kind of enamel. That will remove it without taking the paint off the wheel. Acteone will strip the paint off the rims.
  • Motor Head
  • Motor Head's Avatar
28 Sep 2010 08:47
#402438
www.permatex.com/documents/tds/Automotive/80077.pdf
Here is the manufactures technical sheet.
I don't know where you read to spray it on the "Rotor", it is normally applied to the rear side of the Pads.
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
28 Sep 2010 09:05 - 28 Sep 2010 09:05
#402444
LOL! You sprayed that stuff all over your rotor and hub? Pics?
FWIW - I fixed the window shattering Z1 squeal using some Ultra Black on the back of the pads. ....for now. I plan on trying to recreate those factory pads and shims.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
Last edit: 28 Sep 2010 09:05 by Kidkawie.
  • bountyhunter
28 Sep 2010 11:16
#402470
Yea, normally the "quiet" stuff gets put on the back of the pad. On my bike, it would work for a couple of weeks then start squealing again. I ended up refacing the rotor and that fixed it.
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
28 Sep 2010 12:22
#402483
Apparently, not clearly enough. :blink:
Tough lesson. Nothing ever gets sprayed on pads, and only high flash point/clean drying solvents on rotor.
Good luck.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
