Front Tire "Bounce"
  • Capt America
  • Capt America's Avatar
  • Born Bad
Re: Front Tire
24 Sep 2010 10:03
#401410
TeK9iNe wrote:
The wheels need to be perfectly balanced as the final step of wheel assembly. Of the hundreds of wheels we've changed, never has a wheel not required any weights.
Needs to be perfect, not just close.
Good luck.
B)
I second this motion. Sounds like a balance issue to me.
Capt A merica
1983 K1 750 twin
Ontario, Canada.
  • ed spangler
  • ed spangler's Avatar Topic Author
  • Tennessee Z
Re: Front Tire
24 Sep 2010 11:08
#401437
Hey Kid
Thanks Buddy, got the ground wire from someone,I am all set on that,1 airdjstment screw for a Mikuni VM28??
That I need bad.
As far as the front tire, just got back from checking it out some more ( Yeah , Pity!! I had to RIDE it to check it out!! and of course the weather is BEAUTIFULL here in East Tn. right now ....front tireunce, will pull wheel back off and check it again on the balance machine Good Point TEKNINE!!maybe less than 1/4 ounce is not close enough on the balance, I will see if I can get it closer to perfect.
Despite having carefully rebuilt the front fork tubes,All new parts,carefully measuring the new 10W fork oil etc. etc.on the bike ,hold the front brake and push on the front end, the forks do not seem to depress smoothly and when i let up on it, seems they "Stick" or feel reluctant to come back up.
SO...............I am thinking put some miles on it see if they "Loosen-Up" since all the parts are new and tight.
Any Thoughts?
Thanks Guys for your input!!
Have 1975 Kawasaki Z1-B & 2003 Harley Davidson Heritage Softail Classic
Had Hondas, Harleys and many ,many Z Series Kaws both Std. & LTD's
  • ed spangler
  • Tennessee Z
Re: Front Tire
24 Sep 2010 11:12
#401438
Nope, The rims are from Jeff as are the Stainless Spokes all good stuff, but I am re-thinking my rim theory right now, all eyes on front forks /chassis!! See other post reply to you .
  • bountyhunter
  • bountyhunter's Avatar
Re: Front Tire "Bounce"
24 Sep 2010 11:16 - 24 Sep 2010 11:18
#401441
If it bounces at all speeds, it is probably a bent wheel. I have never seen a balance so bad it would bounce at all speeds. usually you have to get it about 50 mph to feel a balance problem.
Other possibility: is the tire's bead seated all the way around the rim?
Last edit: 24 Sep 2010 11:18 by bountyhunter.
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
Re: Front Tire
24 Sep 2010 11:20 - 24 Sep 2010 11:21
#401445
Any Thoughts?
The miles put on could destroy a part that is causing the un-smooth operation. Try thoroughly lubricating the inner (top) fork tube while on the center stand, then gently lift the fork seal edges with something plastic, and have a friend gently rock the bike/forks up and down. Lubricate the seals all around, and see if that helps.
If sticking persists, then there is deffinately an assembly/part issue. Dissasemble and check forks for trueness, or an out-of-round condition.
Good luck.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 24 Sep 2010 11:21 by TeK9iNe.
Re: Front Tire
24 Sep 2010 12:03
#401459
If not already done, would assure tire itself isn't out-of-round.
May be determined on fully assembled bike by rotating the wheel while using a simple fixed position pointer to show any high spot on tire circumference.
Good Fortune! :)
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
Re: Front Tire
24 Sep 2010 12:11
#401461
That I need bad.
Yeah, I got that. I rebuilt all 4 of my carbs, the Sudco kits come with new ones.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
  • ed spangler
  • Tennessee Z
Re: Front Tire
24 Sep 2010 12:41 - 24 Sep 2010 17:00
#401464
Cool!!
Thanks!!
Last edit: 24 Sep 2010 17:00 by ed spangler. Reason: remove Address
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
Re: Front Tire
24 Sep 2010 14:31
#401482
PM your address man! Edit your post, I copied it down.
1975 Z1 900
2004 KX125
  • ed spangler
  • Tennessee Z
Re: Front Tire
24 Sep 2010 17:00
#401500
Done
Thanks
  • trianglelaguna
  • trianglelaguna's Avatar
24 Sep 2010 17:18
#401507
what tire psi is in the front?...the rear
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
