cracked triple tree
- Drod13
cracked triple tree
08 Sep 2010 17:38
I shaved off the tach,speedo mounts and stripped the paint
and found this...Do you think it's safe to weld up or get another and start fresh? Thanks all!
1979 KZ-750
- PLUMMEN
Re: cracked triple tree
08 Sep 2010 17:44
750 twin top tree should be common enough,id replace it
- MFolks
08 Sep 2010 17:45
Aluminum or steel? both can be welded to repair the crack, ask around at the welding shops locally.
08 Sep 2010 18:30
It helps a bunch if you put your year/model in the signature line. Ed
- donthekawguy
08 Sep 2010 18:35
It would probably be cheaper and safer to replace it.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- timebomb33
08 Sep 2010 18:40
do you trust your life to your welding ability i know i don't mine. all i have to say on the matter.
I THINK MY POWERBAND BROKE
- Drod13
08 Sep 2010 20:20
timebomb33 wrote:
I don't weld but my buddies do at work so I'll ask them what they think.I trust their welds with my life...I have to, I hang off the sides of cranes with d-rings they weld up for me to hook my harness to.I also ride a v-star that has the neck raked and I ride that with confidence.It's a sick rake with a total of 52 degree's.
I hear what your saying and I should probably just get a new one but I think my welders could make it as strong if not stronger than stock.I haven't asked them yet cause I'm on vacation but I'll probably swing by work.
they also extended my swing arm and welded the back half of my frame.
1979 KZ-750
- Drod13
08 Sep 2010 20:21
650ed wrote:
Sorry about that...I fixed it thanks.
1979 KZ-750
- Drod13
08 Sep 2010 20:25
donthekawguy wrote:
your probably right.I'm gonna research the part just in case my welders don't recommend it..thanks
1979 KZ-750
08 Sep 2010 20:34
Check Kawasaki.com to see which other years/models use the same as yours then check eBay; it's loaded with them. They're very inexpensive (around $20 or less). Ed
- Rainman
- and a little Kaw shall lead them
08 Sep 2010 21:09
Drod13, have it welded it up and see if you like it. If your not comfortable with the results, I have one you can have. PM me if you want it.
Good luck
Jim
Good luck
Jim
80 KZ750 H1 - the Kaw calf
79 KZ750 Twin - Miss Nov 2008 KZR calander
79 KZ750 Twin parts bike
78 KZ650 C2 Parts Bike
75 KZ400 Wife's old bike sold
81 KZ440 A2 LTD Wife's new bike
84 Honda 450 Rebel Wife's newest bike
Jim
Quincy,IL
Jim
Quincy,IL
- Injected
09 Sep 2010 05:33
I had the same thing happen on my project street bike... upper for mine. I took it to my local motorcycle speed shop - guy runs a top fuel Kawasaki and can weld circles around everybody... he said replace is the only option !
Depending on what it is they are only $10-20 at any salvage yard... the lower might be a bit more $$.
1978 KZ650B2 modified project
