Mags VS Spokes
- trianglelaguna
Re: Mags VS Spokes
20 Aug 2010 10:08
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- JMKZHI
Re: Mags VS Spokes
20 Aug 2010 11:02 - 20 Aug 2010 11:03
Cast alloy wheels are easier & cheaper to restore.
Cast alloy wheels seem to give a better ride (my opinion, however limited).
If there are tubeless cast alloy wheels that'll fit your bike, then often times a nail puncture can be more easily repaired, so that you can get home.
Spoke wheels require maintenance.
Spokes get rusty & are expensive.
Spoked wheels have a tube, so a roadside flat repair is more difficult, if not impossible, for most folks.
I put KZ550 cast alloy wheels on my 81 CSR. Everything from the CSR wheels is the same. The 550s cost $40 total shipped. New spokes for the CSR would've been ~$115/wheel.... plus installation. ouch. Plus I still would've had to deal w tubes.
Last edit: 20 Aug 2010 11:03 by JMKZHI.
Re: Mags VS Spokes
20 Aug 2010 11:42
Nice bike!
- elfmagic17
Re: Mags VS Spokes
20 Aug 2010 12:42
What size wheels are those? I'd like to some of those for my '77 when money permits. JMKZHI wrote:
Kenny Hicks
74 Honda CB550
74 Honda CB550
- Kidkawie
- I bleed premix
Re: Mags VS Spokes
20 Aug 2010 13:02
If you start off with a stock/factory spoke wheel then at some point in the future the coating on the spokes will wear off and they will most likely rust. Factory spokes are not top-of-the-line in any aspect. However, if you build a wheel from scratch using stainless steel spokes you pretty much eliminate the maintenace/rust factor. This is also assuming you take care of your bike. You don't need to constantly torque or maintain your spokes, espescially for street riding. A new wheel will need to be trued initially, then maybe once or twice thereafter while the wheel "settles". After that you're good to go. When my stock MX wheels turn into stop signs I use Excel heavy duty SS spokes and Excel rims. I can race all season and only have to go over them once.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
- kaw a bong a
- Have a 1978 kz 650 b and a 1976 kz 900z1ltd
- 55fbomb
Re: Mags VS Spokes
20 Aug 2010 15:50
The bike is a 77 KZ1000, sorry i forgot to mention that. and i am thinking about swapping to a stock mag. im not a big fan of mags on most bikes but i do like the stock KZ mags. what i would really like to have is a nice set of Lesters but thats probably out of my price range at the moment. My spoked wheels have seen better days for sure and i think mags may be a cheaper solution than trying to piece together a decent set of spoked wheels. i need to buy tires soon so i gotta decide. . .
1974 CB750
1975 CB750
197? CB750 mutt
1977 KZ1000
1975 CB750
197? CB750 mutt
1977 KZ1000
- JMKZHI
Re: Mags VS Spokes
21 Aug 2010 07:31 - 21 Aug 2010 07:32
elfmagic17 wrote:
For your 77 model, you'd probably have to use either 650-SR or 650-Ltd wheels - I believe those wheels are the same size. The SR has a Rr disk brake. The 650-C has cast alloy wheels, but the rear is 18" w a Rr disk as well. I don't know much about 70s wheel fitment, though. It seems like the 70s stuff is kinda interchangeable... to an extent... and maybe a couple of 1980 models.
I happen to prefer mag wheels & I wanted tubeless. For my bike the wheel swap was as easy as it gets. All of the needed hub components from the CSR are the same as the 550's. The only parts I used from the 550 wheels were the wheels themselves & the Fr disk.
19" Front 16" Rear.What size wheels are those? I'd like to some of those for my '77 when money permits...
Last edit: 21 Aug 2010 07:32 by JMKZHI.
- donthekawguy
Re: Mags VS Spokes
23 Aug 2010 17:15
I have a 18X5.5 on the rear and a 18x3.5 up front on my 77 1000. It handles a lot better with the 18 up front. I had Buchanons build both wheels with heavy duty stainless spokes and I powder coated the rims. They are easy to clean and look sweet!
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- 55fbomb
Re: Mags VS Spokes
23 Aug 2010 19:35
I dont doubt it looks sweet, sounds like a real nice setup but i dont have that kind of coin right now.
1974 CB750
1975 CB750
197? CB750 mutt
1977 KZ1000
1975 CB750
197? CB750 mutt
1977 KZ1000
- donthekawguy
Re: Mags VS Spokes
24 Aug 2010 16:25
Now that I own a house I dont either. Man that 8 grand I got didnt go far lol.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- 55fbomb
Re: Mags VS Spokes
24 Aug 2010 18:59
thats the one thing i do like about keeping my spoked wheels, which i probly will for when i have money to fix them up, but they are just a re-lace and a couple hoops away from wider rims.
1974 CB750
1975 CB750
197? CB750 mutt
1977 KZ1000
1975 CB750
197? CB750 mutt
1977 KZ1000
