Brake Torque Link
- Kyle_w11
Brake Torque Link
12 Aug 2010 11:35 - 12 Aug 2010 11:37
I just got the beast to fire up and run but now I need to take care of this detail before I can ride it. The owner had someone put a GS 1100 swingarm on it 27 years ago. They didnt finish up though.. Now the torque link is dangling leaving me with no rear brakes.
Here's the linkage
From under the swingarm
Here's the GS mount:
If I try to mount the torque link to the GS mount, it's dangerously close to the rear tire but could work temporarily. i'm thinking one of my better options is to have a bracket welded to the bottom of the swingarm.. Does anyone have a suggestion? Previous solutions?
Cheers,
Kyle
Here's the linkage
Cheers,
Kyle
1976 KZ 900 A4 with 1974 Z1 Big Bore Engine - 10,000 mi.
Last edit: 12 Aug 2010 11:37 by Kyle_w11.
- Capt America
- Born Bad
Re: Brake Torque Link
12 Aug 2010 12:09
That whole setup just looks scary to me. If you must, I'd suggest having a good strong double sided tab welded to the bottom of that swing arm. I don't suppose the PO still has the original swing arm kicking around that you could get your paws on?
Capt A
merica
1983 K1 750 twin
Ontario, Canada.
1983 K1 750 twin
Ontario, Canada.
- Kyle_w11
12 Aug 2010 12:47
Nah there's no way i'd get the original swingarm. I've heard this is a common mod so I figured there would be a lot of examples.
- TeK9iNe
- What did you do!?!
12 Aug 2010 12:55
Yeah weld away. Bottom looks fine, I'd go there.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
12 Aug 2010 13:07
you are either going to have to have a tab welded on or use some nutserts and bolt a bracket on.
www.aircraftspruce.com/catalog/hapages/nutserts.php
the nutserts might be the easiest way to "do-it yourself".
hth,
hth,
- MFolks
12 Aug 2010 14:39
If it were me, I'd have a flat "U" shaped bracket with a spacer welded inside for the correct bolt to go through.
It is probably redundit, but I like having a secure anchor for the braking torque that's there.
- donthekawguy
12 Aug 2010 19:57
What size tire are you running? I have a 140/70-18 on mine and have plenty of room.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- Kyle_w11
13 Aug 2010 09:01
donthekawguy wrote:
Do you have a Disk brake setup? The tire clearance comes into question when I try to mount to the inside of the stock GS mount while using the KZ drum brake.. I am going to have to weld to the bottom of the swingarm in order to fit the torque link properly.. i'm running the pizza cutter stock size tire.
- donthekawguy
13 Aug 2010 20:39
Ahh... yes i have a disc brake.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- TerryK
13 Aug 2010 22:18
Make sure you have the proper bolt and bronze bushing in the torque arm or it will go "clunk" every time you use the rear brake.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
- Kyle_w11
18 Aug 2010 08:58
The swingarm has been sent off for some welding.. i'll let you all know how it goes when I get it back!
19 Aug 2010 07:56
keep us posted,
