New Sprockets
  • 1981kz550ltd
  • 1981kz550ltd's Avatar Topic Author
Re: New Sprockets
13 Aug 2010 12:21
#390671
I'm only about 155 lbs. and My dad rides my bike occaisionally. hes around 180. im only 17yrs old. and dont expect to be heavy anytime soon.
  • bountyhunter
  • bountyhunter's Avatar
Re: New Sprockets
13 Aug 2010 18:11
#390732
It should be able to handle the higher gearing no problem, may have to downshift to accelerate up hills but cruising flat will be no worries.
  • 1981kz550ltd
Re: New Sprockets
13 Aug 2010 22:28
#390782
BH, do you recomend the 17/37 combo then?
  • bountyhunter
Re: New Sprockets
13 Aug 2010 22:46 - 13 Aug 2010 22:48
#390786
I think that 17/36 is closest to the RPM value that you said you were going for.
Last edit: 13 Aug 2010 22:48 by bountyhunter.
  • 1981kz550ltd
Re: New Sprockets
14 Aug 2010 11:07
#390837
hmmm. On bikebandit.com. under aftermarket parts. they only have a 38t or higher for the 550. but for the 750. they have down to a 32t. will a 36t for the 750 mount on my 550? i would think it would being the same year.
  • bountyhunter
Re: New Sprockets
14 Aug 2010 12:11
#390852
I honestly don't know. I would use the OEM lookup at Bikebandit to get the part number for the sprocket and see if it crosses to other years and models. Sprocket Specialists sells sprockets in any tooth size but they cost more than the OEM ones. Usually, they are the only way to get smaller rear sprockets. Also, make sure the sprockets are the right chain type (530 or 630 or whatever). I saw small ones for my bike that were the wrong chain type.
  • RoycePHC1
  • RoycePHC1's Avatar
Re: New Sprockets
29 Aug 2010 14:09
#394830
Hey Bountyhunter, I alos have a 79' 750 twin and I am trying to figure out what front and rear sporcet to use. I was thinking of running 17/32. Do you think this will give me at least 15mph more? Also is sprocket specialist the only place to get a 32t rear for 79' kz750 twin. Thanks.
  • MFolks
  • MFolks's Avatar
Re: New Sprockets
29 Aug 2010 14:18
#394834
