old sprockets and new chain
- gcarson64
25 Jul 2010 20:06
what would be the worsed thing that could happen if you used the old sprockets with a new drive chain. the sprockets look fine when you hold them side by side with new sprockets. please let me know thanks
1980 kz550 38,500 miles basket case ( soon to be a BOBBER )
1983 kz550 9,600 miles
1988 jeep grand wagoneer 144,500 miles 4 mpg
- Motor Head
Re: old sprockets and new chain
25 Jul 2010 20:12
Worse thing is it will not wear as long, stretch the chain out to fit the sprockets wear pattern. Then you'll be up for a new set and chain again. Only you can make the judgement since you get to look at the wear now.
Sealed O-ring style chain?
- bountyhunter
25 Jul 2010 20:52
gcarson64 wrote:
The chain will wear out faster than normal. Thing is, a decent O ring or X ring chain will cost close to $100 and new sprockets are maybe $30 so it's a loser to use the old sprockets. Check prices at Z1 Enterprises.what would be the worsed thing that could happen if you used the old sprockets with a new drive chain. the sprockets look fine when you hold them side by side with new sprockets. please let me know thanks
- otakar
25 Jul 2010 21:13
You can sometimes get away with using the old front sprocket because it is case hardened and will last a long time. But rear sprockets are soft and can destroy your new chain.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- kawsakiman
25 Jul 2010 21:57
for christ's sake just buy the sprockets all ready.
z1 has them and there cheap. why risk it?
www.z1enterprises.com/detail.aspx?ID=404
www.z1enterprises.com/detail.aspx?ID=390
for $40 plus shipping be safe and extend the life of you chain and your life.
or not. it's not like it's big Competent . :blush:
- Capt America
- Born Bad
26 Jul 2010 23:52
So every time you guys replace a POS chain, you also replace your sprockets. Wow, I've lived a dangerous life.
Capt A
merica
1983 K1 750 twin
Ontario, Canada.
1983 K1 750 twin
Ontario, Canada.
- otakar
27 Jul 2010 05:45
Capt America wrote:
YES
YES
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Polar_Bus
27 Jul 2010 09:28 - 27 Jul 2010 09:31
Sorry I don't have much mercy for people who jump over a dollar to save a dime. Tires, wheel bearings, brakes and driveline are life threatening motorcycle components that I DON'T cheap out on...
If ya' cant fix it right this month, park the bike and wait till next month not only could you save your life, you might save someone elses'....
Bikes:
'84 GPz1100
'06 HD Fatboy
'84 GPz1100
'06 HD Fatboy
Last edit: 27 Jul 2010 09:31 by Polar_Bus.
- dblhdr
27 Jul 2010 14:01
Polar Bus is right.
You should never skimp on bearings, brakes, tires, chain, sprockets, or lights for that matter. Anything thaty might be a few extra bucks now will look mighty cheap if you get hurt or killed 'cause it broke at 65mph. :S
1981 KZ1000 Police Special coverted for civilian use with passenger seat, custom luggage rack, and paint. Daily rider.
2006 Harley Davidson Road King FLHR1
- baldy110
28 Jul 2010 19:14
Capt America wrote:
Me too.
Me too.
- hardr0ck68
- Who put the what in the where?
28 Jul 2010 19:56
dblhdr wrote:
It is up to the owner of each bike to decide what is safe, I rebuilt my brakes but re-used the pads because they has a lot of material left did I skimp? yes, does the bike stop better than ever yes.
If you think the sprockets have little to no ware then just make sure to watch your new chain for wear. It's not like a worn sprocket will cause a chain to go from new to dangerously out of spec on the way to the corner store for a pack of smokes.
Now if there is a good reason to pick up sprockets as well, it is for a 520 swap; get rid of that old 620 anchor chain and put something more reasonable on!
Polar Bus is right.You should never skimp on bearings, brakes, tires, chain, sprockets, or lights for that matter. Anything thaty might be a few extra bucks now will look mighty cheap if you get hurt or killed 'cause it broke at 65mph. :S
1977 kz650 c1
bought it because I was told it would never run again...I like to prove people wrong.
- DFIGPZ
28 Jul 2010 21:10
Capt America wrote:
me 3 i am not risking my engine cases or MY LIFE!So every time you guys replace a POS chain, you also replace your sprockets. Wow, I've lived a dangerous life.
1984 750 Turbo
