Castle nut
  • Topper
  • Topper's Avatar Topic Author
Castle nut
14 Jul 2010 17:26
#382678
Trying to take the front wheel off my '88 KZ305 LTD. None of my sockets are big enough for the castle nut. Before I go buy a bunch of new ones, can anyone tell me what size that nut is?
Also, when I put the wheel back on, do I need to use a torque wrench or do I just tighten it down as much as I can?
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
  • otakar
  • otakar's Avatar
Re: Castle nut
14 Jul 2010 18:54
#382707
14mm
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • Topper
Re: Castle nut
15 Jul 2010 05:50
#382806
otakar wrote:
14mm
I've got a 14mm socket and it doesn't come close to fitting. You sure that's right?
1979 KZ750 Twin
  • JMKZHI
  • JMKZHI's Avatar
Re: Castle nut
15 Jul 2010 06:24 - 15 Jul 2010 06:28
#382807
I don't know what size your front axle nut is, but I'd guess it's bigger than 14mm. The one on my KZ650 is 19mm, but it isn't a castle nut.
As for tightening it, you should try to use the proper torque. However, if your front castle nut is like the rear one on my bike, you may have to simply tighten it down until you can fit the cotter or hitch pin in there. I use a crescent wrench. I don't know what the torque spec is for your bike. I would use a torque wrench, then tighten it more if necessary to install the pin.... unless someone w more experience has a better idea.
Last edit: 15 Jul 2010 06:28 by JMKZHI.
  • otakar
  • otakar's Avatar
Re: Castle nut
15 Jul 2010 06:42
#382810
Topper wrote:
otakar wrote:
14mm
I just went to kawasaki.com and looked up your bike. It states 14mm 42045-020. But that might be the axle size also. Why don't you just measure it. Since you know it is metric it will be to the closest mm. When the nuts get that big they are not even in single mm increments so it will be simple to measure and approximate if you don't have calipers.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
Re: Castle nut
15 Jul 2010 08:07
#382827
I never saw a front axle with a cotter pin.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
  • H1Vindicator
  • H1Vindicator's Avatar
Re: ----
15 Jul 2010 08:35 - 20 Feb 2013 20:29
#382833
Last edit: 20 Feb 2013 20:29 by H1Vindicator.
  • djturnz
  • djturnz's Avatar
Re: Castle nut
15 Jul 2010 09:22
#382839
Assuming you have the tool kit, it should have the correct size wrench.
I hate cotter pins, no more cotter pins, 'R' clips and safety wire from here on out.
1982 KZ750 (4) LTD
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
Re: Castle nut
15 Jul 2010 09:33
#382842
Kawasaki never got with the times on their MX bikes. All my KX250's came with castle nuts on the rear axle. I swap them out with Honda nylock nuts.
1975 Z1 900
2004 KX125
  • hocbj23
  • hocbj23's Avatar
Re: Castle nut
15 Jul 2010 10:45
#382851
front axle nut on KZ1000s (at least mine) is 19mm and it isnt a castle nut and no place for a cotter pin,r pin or safety wire.Rear axle has such a place.bj
  • steell
  • steell's Avatar
Re: Castle nut
15 Jul 2010 12:45
#382861
When Kawasaki says it's a 14mm nut, it's absolutely correct. Nuts are listed by the diameter of the bolt they screw on, like 3/8" nut fits a 3/8" bolt, and usually takes a 9/16" wrench or socket.
19mm wrench for a 14mm nut sounds reasonable to me.
  • Topper
Re: Castle nut
15 Jul 2010 12:51
#382863
I'm going to give 19mm a shot. We'll see how that goes.
What about the need for a torque wrench when putting the wheel back on? I'd like to hear some more opinions on that.
Obviously I don't want my wheel falling off (or wobbling). Is tightening it down as much as I can (providing I can get the cotter pin in) enough? Or do I really need to tighten this to a specific torque setting?
1979 KZ750 Twin
