European bars?
  • otakar
  • otakar's Avatar
Re: European bars?
27 Jun 2010 16:09
#378627
I guess it won't allow me to put more than one picture in one post. Here is the picture.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • otakar
  • otakar's Avatar
Re: European bars?
27 Jun 2010 16:10
#378628
Her's a closeup.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • otakar
  • otakar's Avatar
Re: European bars?
27 Jun 2010 16:16 - 27 Jun 2010 16:21
#378631
roy-b-boy-b wrote:
Euro Bars from Z1enterprises.
Actually, Looking at those bars and comparing them to the link provided by Patton, thy may be even Daytona Bars. They have quite a bit of Rise. Much more than the 2.4" of the Euro bar. The rise is measured not from center to center but from absolute bottom to absolute top when the risers are laid flat upside down on a flat surface. They also seem to have more pullback than my Euro-bar.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 27 Jun 2010 16:21 by otakar.
  • otakar
  • otakar's Avatar
Re: European bars?
27 Jun 2010 16:25
#378636
Here is the best image I have found of all the bars in one picture and in comparison.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • otakar
  • otakar's Avatar
Re: European bars?
27 Jun 2010 16:26
#378637
Here is the Z1E euro bar picture.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • kaw a bong a
  • kaw a bong a's Avatar Topic Author
  • Have a 1978 kz 650 b and a 1976 kz 900z1ltd
Re: European bars?
27 Jun 2010 17:00
#378642
after looking at all those bars and the bikes ,I think otakar's bars are what Im looking for..thanks to all,I actually like the daytona's too from the pic,they might be alittle too high tho?thanks again will post with the new bars asap.
1978kz650b 1976kz900 first bike 1979kz 400
  • otakar
  • otakar's Avatar
Re: European bars?
27 Jun 2010 17:27 - 27 Jun 2010 17:34
#378650
I would like to apologize to everyone here. I just went threw my order history at BikeBandit where I bought these bars and have discovered that these are actually the "black Superbike Bars" by BikeMaster. The reason I got confused was because I was not sure myself which bar I would like the best so I bought five different sets of bars. The Euro bars do not come in black so that leaves the "Superbike Bar" Part # 11-0510 the chrome ones are #11-0511. They are also available from Z1E. They have about a half inch more reise than the Euro bars but almost two inches less in pullback. They are also about three-quarters of an inch narrower than the Euro bar.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 27 Jun 2010 17:34 by otakar.
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
Re: European bars?
27 Jun 2010 19:21 - 27 Jun 2010 19:22
#378668
And I thought I was going to have to hit Rob over the head with my euros.
The bike came with drag bars and they were the pits. I have a few of them laying around. Roy
Last edit: 27 Jun 2010 19:22 by roy-b-boy-b.
  • kaw a bong a
Re: European bars?
27 Jun 2010 19:49
#378672
these are my bars,I just found a pic,and probably will order more than one bar to find a fit I like.
  • Jeff.Saunders
  • Jeff.Saunders's Avatar
  • Vendor
  • Vendor
Re: European bars?
28 Jun 2010 05:58
#378713
While many manufacturers appear to sell the same handlebars, the dimensions tend to change a little.
You do need to pay attention to the rise, pull-back and center section width.
There are no industry specifications for handlebars - other than 7/8" (most bikes) or 1" (harley).
With the LTD bars, there is a significant pull-back different in brands. The width of the drag bars change as much as 3". Ranging from 27" to 30". This all impacts fitment of master cylinders and clutch perches...
  • Old Man Rock
  • Old Man Rock's Avatar
Re: European bars?
28 Jun 2010 06:13
#378717
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • Jeff.Saunders
  • Vendor
  • Vendor
Re: European bars?
28 Jun 2010 06:17
#378718
The one piece of information not typically provided, is the angle of the grip portion of the bars.
For example, the bars on a Z1 are essentially level to the ground in the grip area. H2 bars are turned downward about 20 degrees.
