My rear brake is too bad and needs improving
  • otakar
  • otakar's Avatar
Re: My rear brake is too bad and needs improving
11 Jun 2010 10:58
#375089
Both of those points have been covered already. I would hope that those would have been checked by now.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • H1Vindicator
  • H1Vindicator's Avatar
Re: ----
11 Jun 2010 19:22 - 21 Feb 2013 01:50
#375181
Last edit: 21 Feb 2013 01:50 by H1Vindicator.
  • bountyhunter
  • bountyhunter's Avatar
11 Jun 2010 19:47 - 11 Jun 2010 19:52
#375188
here is the OP's response:
The pads and fluid are as new as the disk
Then later:
The disk, the pads and the fluid was changed at the same time.
What does "as new" mean? Used in good condition? Are they original? Come off another bike? When the disk was changed, was it surfaced or just thrown in with new pads? I'm still wondering.
Last edit: 11 Jun 2010 19:52 by bountyhunter.
  • bountyhunter
11 Jun 2010 19:54
#375189
Schorly wrote:
The disk, the pads and the fluid was changed at the same time. I didn’t change the hoses and may have not flushed the system through enough to get rid of all the debris. So I will do this next and see if the braking improves. If not I might have to live with the inefficiency of the rear brake as it has been mentioned by other comments.
I don't know who's telling you the rear brake is "inefficient". Mine will lock the rear whell no problem with a good tap of the toe. If yours won't, something needs to be fixed. The old KZ brakes may not have state of the art heat dissipation of dual disc modern bikes, but they will certainly grab the wheel and lock it if you stand on them.
