Rear Swingarm Conversion Question
  • Yamatr3
  • Yamatr3's Avatar Topic Author
Re: Rear Swingarm Conversion Question
10 Jun 2010 18:45
#374970
Wow guys, thanks for all the good info. I think I'm going to go for the aluminum Zephyr arm. There is one local I should be able to pick up.
I learned something today. in many, many threads, everyone always says look at OMR's build. I searched and searched and could not find a member by OMR. Then Old Man Rock replies to my thread and it clicked LOL!
  • camaroguy
  • camaroguy's Avatar
11 Jun 2010 03:44
#375037
That rz is real nice. been kinda looking for one for next build.as far as swingarms. look up kanos gpz I think he used the whole asss end off of a gsxr 1000 and just welded shock mounnts to it.wheel, brakes, axle, everything.or try to find a zx6 swing arm and see if you can turn it over and use the upper brace as a new lower underbrace welding shock mts to it??have to look at wheel off set?
  • mjg15
  • mjg15's Avatar
11 Jun 2010 04:51 - 11 Jun 2010 04:54
#375041
If you get bored with the RZ HP check out this:
www.twostrokeshop.com/two_stroke_shop_engines.htm
And, some more Zephyr info:
kzrider.com/index.php?option=com_kunena&...d=5&id=354020#354364
'80 Z750fx
'81 KZ550A
'81 GPz550's, Too many!
'82 KZ1000R
'82 GPz750
'90 ZR550
Project photo album: s163.photobucket.com/albums/t289/mg15_ph...GPz-ZR550%20project/
s163.photobucket.com/albums/t289/mg15_ph...current=DSC01286.jpg
Last edit: 11 Jun 2010 04:54 by mjg15.
  • 9am53
  • 9am53's Avatar
  • homebrew, and some bbq
11 Jun 2010 07:53
#375060
sorry if this is hijacking, but it's kind of on topic...why do some reinforced swingarms have the reinforcing tube pointing up, and most of our older bikes that have been converted have them pointing down?
  • hocbj23
  • hocbj23's Avatar
11 Jun 2010 11:29
#375101
on J bikes u have clearance issues by pointing them up-not so much with pointing down except losing the center stand.bj
  • smk0733
  • smk0733's Avatar
31 Jan 2011 20:21
#427547
i have a question about a 82 kz 750 shaft drive frame.any suggestions to converting it to a chain drive swingarm the spacing is about 4 inches more.does anyone make a swing arm bolt for that conversion
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
01 Feb 2011 11:25
#427660
A ZX6R is about 100# lighter than that 900 so your spring rates are going to be way off.
Nice dining room.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
  • porchev914
  • porchev914's Avatar
01 Feb 2011 13:55
#427677
That can be mitigated though with heavier springs.
FRANKEN Z!
  • PLUMMEN
  • PLUMMEN's Avatar
01 Feb 2011 18:24
#427725
omr is easy to find,hes usually sitting in his chair building/modifying something! :woohoo:
  • jeffasaki
  • jeffasaki's Avatar
01 Feb 2011 19:12
#427731
The easiest way and the best way to do a dual shock aluminium swingarm is to get one from a about a 82 GS1100E suzuki.
Its the same as the one I run EASY swap but youll have to change the shocks as well
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
  • big mike
  • big mike's Avatar
03 Feb 2011 15:22
#428201
how many threads on swing arms are there??
  • hocbj23
  • hocbj23's Avatar
03 Feb 2011 15:49
#428216
11,096,050 or thereabouts.bj
