removing old tapered stem bearings
- yggy
- more wrenching than riding!
23 May 2010 10:19
Hi,
my stem hold s old tapered bearing rollers.. they are completely shot. alot of play is on them and they have pitting all over. SO deciding to swap them for a new set i got a question.. i know how to remove the cups that sit in the stem. do any of you guys have any tips on how to remove the lower tapered bearing? its quite stuck to the lower stem fork..
any tips are much appreciated!
1980 EU-z650 c4 one of the few C's around..
- PLUMMEN
Re: removing old tapered stem bearings
23 May 2010 10:24
long piece of rod and big hammer will knock the old races out,check with local mechanic to see if he has something to remove bottem bearing.
to reinstall the races i use a piece of 1" all thread with a nut and fender washer on each end and 2 pvc couplings to make a press to install them
- Capt America
- Born Bad
23 May 2010 10:38
I'm not much good with the lingo
, if we're talking the bottom bearing on the lower tripple tree... well most kits come with a new dust seal.
If you don't mind detroying the old dust seal, I've always been able to remove them with a ball joint/tie-rod fork.. working one side then the other.
If you don't have one around you can carefully do the same thing with a flat screwdriver.. slowly and carefully working each side. Once you have it up about 1/4 inch it's easy enough to get under it and work it off.
Capt A
merica
1983 K1 750 twin
Ontario, Canada.
1983 K1 750 twin
Ontario, Canada.
- yggy
23 May 2010 11:12
hi, i just ran out and made a picture of the troublemaker
click on it for closer view:
so i would like to get the whole bearing replaced..but im not sure how i could pry it up and out (without damaging it too much
- PLUMMEN
23 May 2010 14:14
- Old Man Rock
23 May 2010 15:18
Cut (90 degree hand grinder with cutting disk or Dremel) the sonsabitch off.... :evil: :whistle:
Personally, take it to a shop and have them do it for what $20.... While your at it, have them press the new one on...
Might save you a whole lot of head ache and frustration and the all mighty "OH SHIT" factor that is a common phrase here... :blush:
Now before all get their big girl princess panties in a bind, sure attempt it with the tools you have but some things without the proper tools are doomed for Uh-Oh....
We've all been there... :blush:
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- JakeB
23 May 2010 15:41
I used a dremel with a small cutting wheel, when I was getting close to the stem I used a cold chisel to crack the race through to the stem. After that it basically fell off.
Good luck!
Good luck!
1978 Z1-R
- loudhvx
23 May 2010 15:58 - 23 May 2010 16:01
The tapered roller races don't have any lip to catch so there is not way to hammer them out directly. As Jake said, use a dremel if you have it, but it takes forever to cut them the right way. Do not cut into the frame tube! You don't need to go 100% through, just 90 to 99%. Then crack it with a hammer and chisel to bust it out.
The easiest way is to mig weld a pipe or big washer to the race and hammer it out. If you don't have a hammer, then I think the dremel is the safest way. It'll take about 4 or 5 full cutting disks for the dremel on the frame tube. Then you'll need another 1 or 2 for the race on the stem.
If there is a proper tool, I'd like to know what it is, I'll gladly get it it because this is a huge pain in the ass. Rollers last a long time, but not forever. Like I said, there is nothing protruding to grab onto, so I don't see how any tool can do it, without welding.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 23 May 2010 16:01 by loudhvx.
- yggy
24 May 2010 03:07
ok, ill try it with the dremel, if i fail im just gonna ask a local motorshop to help me out..
thx!
teh yggster
thx!
teh yggster
- yggy
25 May 2010 05:06
so the dremel thing didnt work out that well (i couldnt find the damn tool! :laugh: note to self: never lend out tools, u will never get them back!)
anyway, just popped of to a local bikeshop, they removed it for me and they even popped on the new one! 20 bucks well spend!
- loudhvx
25 May 2010 08:44
yggy wrote:
Definitely. Did you see how they did it?
1981 KZ550 D1 gpz.
Other links.
Other links.
- yggy
26 May 2010 03:01
hi,
nope, they didn't want to tell me either (they where quite busy it seems.)
they did tell me that they have a tool with some kind of hydraulic thingie.. and that it was a job of seconds.
