New Discs and pads
  • Fergie
  • Fergie's Avatar Topic Author
New Discs and pads
16 May 2010 07:42
#368243
Just fitted new dics and pads to my Z650-F4 (dual front discs) The inner pads on both sides are only touching the outer edge on the discs. i had a look at the old pads and they also seem to be worn more at this point.
I measured the calipers and there is a difference. Like they have spread slightly at the toes.
Do I just run it like this and wait for it to bed in?
Hope that all makes sense. See photos below.
Z650-F4 1984 UK Spec
JMC Aluminium swingarm.
Harris 4-1 exhaust.
  • otakar
  • otakar's Avatar
Re: New Discs and pads
16 May 2010 07:49
#368245
It looks like your caliper is not floating properly or something is bent WAY out of position.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
16 May 2010 07:56 - 16 May 2010 07:57
#368246
Agreed.
They should seat flat at all times.
New or old pads.
Calipers dont really bend... check to make sure bolts are nice and straight, and correct size.
Something is a foot! :laugh:
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 16 May 2010 07:57 by TeK9iNe.
  • Fergie
16 May 2010 07:59
#368248
No, calipers floating okay. Outer pads are sitting okay against the discs. See pictures below. Seems to be that the gap is bigger at the toes of the calipers. Do I file these down to make it even or just leave it to bed in??
Harris 4-1 exhaust.
  • Fergie
16 May 2010 08:30
#368251
More phots of caliper off mounts.
There appears to be about 1mm difference between the front edge and the back.
Harris 4-1 exhaust.
  • otakar
  • otakar's Avatar
16 May 2010 08:37
#368253
Something is wrong with those calipers or you are not putting the pads in right. Don't file anything find out what is wrong. Fix it right.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
16 May 2010 09:42
#368271
Measuring the calipers that way is not going to tell the true story. they may have been cast that way. i would try this. Remove the pads and try to do a similar measurement at the pistons. try to see if there is a dif in distance between the front and rear of the pistons .this may give u a more accurate picture of the alignment.
the pistons should move in and out in line with the bore.
try moving the pistons in and out and repeat the measurement to see if the alignment stays the same or differs.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • otakar
  • otakar's Avatar
16 May 2010 10:28
#368279
I think that he only has a single piston, and the caliper jaw is machined in the casting. It should be straight. sometimes corrosion builds up on the jaw and must be removed or mud builds up and has to be removed. I would try to operate the caliper while not mounted to see exactly what it is doing. Just mount the pads and close them onto each other without the disc.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
16 May 2010 13:21 - 16 May 2010 13:21
#368315
thats along the lines that i was thinking. something(rust?)may be causing the piston to run a scew, if it doesnt measure up correctly(true to bore).
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 16 May 2010 13:21 by mark1122.
  • Fergie
16 May 2010 13:24
#368316
Okay, I have measured it a few times now. Casting, piston, with pads etc. Definately slightly wider at the toes. You can just about see it by eye without measuring. If you notice in the last photo there is blue paint. This is off the back of the new pads and is only rubbing at that point. The bike has done over 50k so may just be an age thing.
I have carefully taken about 1/2mm from the back side with a dremel tool, refitted the pads and taken it for a run. Much better. A few more miles and I think it will be beded in correctly. Better feel on the lever also.
Harris 4-1 exhaust.
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
16 May 2010 13:35
#368317
is it just rubbing on the outer edge on the inner side of the disk? is the piston side rubbing evenly?
does it seem that the casting is bent outward?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • Fergie
16 May 2010 14:00 - 16 May 2010 14:05
#368332
Yes, yes and yes. The second set of photos shows the outer surfaces of the discs. Looks like the castings are worn or slightly eased apart over time.
Harris 4-1 exhaust.
Last edit: 16 May 2010 14:05 by Fergie.
