Front wheel calipers bending disc?
  • mind2find
  • mind2find's Avatar Topic Author
28 Apr 2010 08:02
#363819
Hi y'all,
I've just reassembled my front wheel. I don't know if this was happening before, but when I squeeze on the front brake, I can visibly see the caliper pulling the disc and wheel to the left slightly. It's not dramatic and there's no harsh grinding when I roll the bike back and forth, but I hesitate to ride it before asking, is this normal? I'm sure I have all the parts on (axel spacer, speedo, etc. etc.).
The back caliper doesn't do this...
-sf
1976 KZ-750B1 (late model)
1976 KZ-750B1 (early model) Parts Bike
Boston, MA
  • baldy110
  • baldy110's Avatar
Re: Front wheel calipers bending disc?
28 Apr 2010 08:18
#363822
The caliper should go to the disk. The disk and wheel should not move. I would make sure your caliper is free to slide in and out as it supposed to.
  • mind2find
28 Apr 2010 08:50
#363824
Hm, yes, that makes sense. I'll have to look at that. Is there a way to lubricate that motion?
Boston, MA
  • 79MKII
  • 79MKII's Avatar
  • Love Them Kaws!
28 Apr 2010 09:37 - 28 Apr 2010 09:39
#363834
The calipers definitely need to "float". They basically move side to side on the bolts that go all of the way through the caliper and have a nut on the back side. These are not the mounting bolts, but the other 2. Those can be cleaned and greased - might help if it's stuck. (assuming your calipers are like the 900/1000 calipers)
Just happened to think - could the mounting bracket be on the wrong side of the disc? Not sure it that's even possible but it wouldn't float properly.
The Kaw List:
Last edit: 28 Apr 2010 09:39 by 79MKII.
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
29 Apr 2010 14:56
#364265
make sure they are clean and slide easy, but i would not recomend grease. the high heat of the cals can melt the grease, and allow it to runn onto the pads. :(
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • 79MKII
  • 79MKII's Avatar
  • Love Them Kaws!
29 Apr 2010 16:38
#364281
Good point. I only use a tiny bit of high temp grease - a very thin coating. Basically try to wipe it clean with your hands and just leave what's left.
I never thought of it until now but the little packets of lube they sell at auto parts stores specifically for brake calipers would probably work pretty well.
The Kaw List:
  • Zthou1977
  • Zthou1977's Avatar
08 May 2010 08:50 - 08 May 2010 08:52
#366427
I always use "copper grease" (the same you use on stainless bolt-threads to prevent them sticking to the aluminium) on the sliding caliper parts, and it works perfectly. It is specially formulated for high temps.
1977 Z1000A1, 1982-1986 KZ1000P (built from two piles of parts), Moto Martin Z1200 (trying to get it registered), 1977 Z650B1
Utrecht, The Netherlands
Last edit: 08 May 2010 08:52 by Zthou1977.
  • 79MKII
  • 79MKII's Avatar
  • Love Them Kaws!
08 May 2010 10:34
#366453
mind2find - any update on the brakes? Did you find anything that might be causing it?
The Kaw List:
  • loudhvx
  • loudhvx's Avatar
08 May 2010 10:48 - 08 May 2010 10:49
#366455
I believe you are supposed to use Sil-Glyde. It is a silicone grease meant to go on disc brake caliper slide rods. It is specifically not a petroleum-based grease so it should not affect the elastomers used in brake caliper construction.
Do not use too much, just enough to keep water out and lubricate. The boots should prevent it from melting out. Make sure the boots are in good condition for this.
agscompany.com/downloads/datasheet/brake_lubricant_-_tds.pdf
Last edit: 08 May 2010 10:49 by loudhvx.
08 May 2010 11:02
#366460
If needed:
Click here > Caliper Kit from Z1E
Good Fortune! :)
  • mind2find
08 May 2010 11:02
#366461
Hey, yes, sorry, I looked at the caliper and it's definitely not sliding, so I'm going to have to grease those. It seems like the obvious fix. I rode through a lot of dusty roads in New Brunswick last year and coated my entire bike with thick orange-brown dirt. I can't imagine that helped. :)
What I'm wondering now is if I can take one bolt out at a time without having to remove the entire caliper or wheel or brake-line. I could pop one out, lubricate it, reinsert, and do the next. I know it sounds like I'm being lazy, but it's a trial with my bike because I don't have a center stand (ripped off by something before I owned it).
Boston, MA
08 May 2010 11:14
#366467
Due to life and death importance of properly functioning brakes, I would strongly urge getting an FSM and doing the job right. B)
Good Fortune! :)
