77 kz 1000 fork tube
19 Nov 2010 12:53 #413437 by Patton
Replied by Patton on topic 77 kz 1000 fork tube
"Gator Grip" Socket
[Click on image to enlarge view.]
Good Fortune! :)
19 Nov 2010 13:34 #413446 by 650ed
Replied by 650ed on topic 77 kz 1000 fork tube
Another homemade approach...
Fork Tool
19 Nov 2010 17:09 #413472 by TerryK
Replied by TerryK on topic 77 kz 1000 fork tube
I've never had to use a retaining tool as long as I used an air impact gun.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
19 Nov 2010 17:15 - 19 Nov 2010 17:20 #413474 by ironpan65
Replied by ironpan65 on topic 77 kz 1000 fork tube
Finally got it out....Couldn't find a Gator Socket in town here....found something similiar....but wasn't strong enough to use again....stick didn't work...used an impact for allen bolt
May have damaged it too much to use again...sure was tight in there....looked like maybe some kind of locktight was used last....The other fork could be a challenge....
Sure would like to see what the inside of Factory tool pic #10-1 looks like......(cylinder holder adapter)
UNTOLD
Last edit: 19 Nov 2010 17:20 by ironpan65.
19 Nov 2010 17:23 #413476 by TerryK
Ouch!! :ohmy:
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
20 Nov 2010 04:15 - 20 Nov 2010 04:16 #413514 by Patton
ironpan65 wrote:
...Sure would like to see what the inside of Factory tool pic #10-1 looks like......(cylinder holder adapter)....
Just to confirm, (24) Part# 57001-142 is for 1977 KZ1000-A1, and (10-1) Part#57001-176 is for earlier model.
See also kzrider.com/index.php?option=com_kunena&...ew&catid=5&id=223938
where KZCSI posted:
...Kawasaki part number 57001-176. It's basically a 3/8" socket that's made to fit onto a 9/16" dia. round with two flats.
Good Fortune! :)
Last edit: 20 Nov 2010 04:16 by Patton.
20 Nov 2010 04:28 - 20 Nov 2010 04:31 #413515 by JMKZHI
Replied by JMKZHI on topic 77 kz 1000 fork tube
Try applying some heat to the allen bolt w a propane torch before trying to remove it.
Last edit: 20 Nov 2010 04:31 by JMKZHI.
