Sometimes a pothole filled with water is invisible on a wet road.
Ker-whop! :pinch:
Ok if you like riding through standing water be my guest. As hydroplaning on two wheels is not a proposition I take lightly I would never ever ride in to a spot covered with water but I get your point. There are people who throw caution to the wind and for them they need the protection an extra rubber gives them. :blink: :blush:
The spoked tube-type wheels typically have rim stoppers or bead protectors to lock the tire onto the rim. My 81 650-CSR has them. The tubeless wheels I've seen - KZ440 & KZ550 - don't have the holes for installing rim stoppers (bead locks)...As it concerns tire slippage on the rim, I'd just like to point out that my old spoked, tubed rims on my 650 had these rubber dealies bolted in to help hold onto the tire. I'd imagine most Kawi spoked rims were similar, as is usually the case.
Patton wrote:Sometimes a pothole filled with water is invisible on a wet road.
Ker-whop! :pinch:
Sometimes you get stuck riding in the rain and a water-filled pothole can blend right into a wet road, expecially at night.
