To cut down vibration you can eliminate some common sources. Make sure your motor mounts are torqued properly, the carbs are synched, and you can try a Barsnake or similiar method to dampen the vibes in the bars. New grips will help too.
Cashion, OK
78 KZ650 B2 85,000+ miles
