Scored Very nice Zephyr swingarm on eBay
- mjg15
Re: Scored Very nice Zephyr swingarm on eBay
18 Mar 2010 15:33
This a 750 arm. Notice side beams have no indentation and bracing is different. 9 1/4 wide at pivot.
'80 Z750fx
'81 KZ550A
'81 GPz550's, Too many!
'82 KZ1000R
'82 GPz750
'90 ZR550
Project photo album: s163.photobucket.com/albums/t289/mg15_ph...GPz-ZR550%20project/
s163.photobucket.com/albums/t289/mg15_ph...current=DSC01286.jpg
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
- OnkelB
18 Mar 2010 15:47
Ok, thanks. Clearly different from mine, I'll go measure mine tomorrow.
77 KZ 650 B1, 82 GPz 1100 B2.
- otakar
18 Mar 2010 16:30
It also looks a lot more beefy than the 550 arm.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- cherrymetal
25 Mar 2010 13:22
Has anyone thats fitted a Zephyr arm to their 650 had any problem with the angle of the shocks? It looks like the lower mounts (on the arm) are further apart than the top mounts (on the 650 frame), so when the shocks are in operation, its going to try and push the swingarm mounts apart?
_____________________________________________________
1977 Z650 (WIP - GPz750 Engine, RF400 Wheels & brakes, Bandit 600 Forks, Zephyr Swingarm)
1997 ZRX1100 - Stock - for now!(except for Hindle header with Micron carbon can)
1988 NTV600 Revere - Stock (work hack!)
- otakar
25 Mar 2010 17:40 - 25 Mar 2010 17:43
It is not much different than angled shocks on a car. If they are spread apart at an angle it is only very little so. It shouldn't cause any problems. I am putting mine on a KZ1000 frame and I do not know if the rear frame is any wider or not than the 650. The pictures of the 650 in the preceding pictures seam not to have any issues.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 25 Mar 2010 17:43 by otakar.
- otakar
25 Mar 2010 17:44
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- cherrymetal
25 Mar 2010 23:39
But surely on a car the pivot point is in the same plane as the shocks, so the pivot will be complimenting the shock moment rather than fighting against it?
- otakar
26 Mar 2010 06:06
You have rubber dampers both top and bottom, that should be enough to compensate the little deviation you might have.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- KawiConvert
08 Nov 2013 15:57
Did the lengths ever get posted. I'm interested to see what the differences are from stock.
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
- JeepCJ
08 Nov 2013 18:48
I have one on my 91 Zephyr 750 C1 its nice
Bob
Bob
- KawiConvert
08 Nov 2013 19:37JeepCJ wrote: I have one on my 91 Zephyr 750 C1 its nice
Bob
Can you post the distance from the swingarm pivot to the rear axle. Been trying to find an arm close in length to the 650.
Thanks!
- OnkelB
09 Nov 2013 08:45
My ZR550 arm measures 552 mm/20.55" from pivot bolt center to rear axle center - note that this measurement can vary about +/- an inch depending on the position of the axle eccentrics, mine are pretty much in the middle with the axle at 12 o'clock.
The following user(s) said Thank You: KawiConvert
