Master Cylinder Alternatives?
- 9am53
- homebrew, and some bbq
Re: Master Cylinder Alternatives?
09 Feb 2010 11:43
so you can barely pull it and it doesnt want to brake, and then it locks against the rotors and you can't get it to loosen?
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
'71 CB350
- Colossus
09 Feb 2010 13:46
No, sorry. It feels a little loose to start out and brakes normally. As I ride and use it more it starts to build pressure and becomes hard to pull. And locks against the rotors and sticks. Right now it's loose again.
1981 KZ550A2
- rstnick
09 Feb 2010 13:57 - 09 Feb 2010 13:58
I'm not familiar with the working innards of a MC, but have an idea.
Pressure is building in your brake system, but it's not subsiding normally. It keeps building, then locks up the brake.
There is a small hole/valve in the MC that's supposed to allow the fluid back through, thus decreasing pressure, and I bet yours is clogged.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
Last edit: 09 Feb 2010 13:58 by rstnick.
- Colossus
09 Feb 2010 14:23
Okay. I thought I got everything sorted with it but I'll take it apart and start over again. Thanks.
1981 KZ550A2
- 9am53
09 Feb 2010 14:54
on the mc's I have seen there are 2 little pinholes that you can poke out with a toothpick
'84 GPz900r
'71 CB350
'71 CB350
- Colossus
09 Feb 2010 15:08
it's the kind that has a remote reservoir. Do you know where I might find those holes? Sorry I would post a pic but my camera's not working. It'll probably be pretty obvious when I tear it all apart again. Sorry for being such a high-maintenance poster.:blush:
1981 KZ550A2
- 9am53
09 Feb 2010 15:14
I have only really taken apart the old style mc's, but I would assume the holes would be under the fitting that the hose slips on, can you remove that fitting?
'84 GPz900r
'71 CB350
'71 CB350
- Colossus
09 Feb 2010 15:25
Once I take it apart again I'll check it out. Unfortunately I have to go to work now so maybe in a couple of days. Thanks for all the help. That sounds like a logical solution.
1981 KZ550A2
- 9am53
09 Feb 2010 15:27
hopefully it works out for you, I have found the best advice I ever got regarding brakes is that just taking them completely apart and cleaning them thoroughly with clean brake fluid usually magically fixes many issues.
'84 GPz900r
'71 CB350
'71 CB350
- Colossus
11 Feb 2010 00:45
Okay... Disassembled the MC again and cleaned it just the same. There's only one hole that lets the fluid flow to and from the remote reservoir. The entire thing is pristine now. Haven't hooked it back up yet. I have one question before I do. The new MC didn't come with a banjo bolt. I'm using the same stock banjo bolt that my original kz550 MC came with. This may seem like a stupid question but could that be my problem? It fits but some of the Nissin models I looked at online have different shaped banjo bolts. I've looked endlessly for some kind of back catalog or listing of their different models to find the matching bolt to no avail. I would hate to bleed that line again and have the same problem. Am I not allowed to curse on this board? I sure would like to right now.:blink:
1981 KZ550A2
