GS1100 swingarm
- Kawickrice
Re: GS1100 swingarm
25 Jan 2010 10:47
nebiker51 wrote:
Ditto. My local ACE has the best selection of metric stainless fasteners locally. I have done two out of three bikes so far using ACE.
The Ace Hardware in our area has a real good selection of stainless steel nut, bolt and washers in both metric and sae.
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- riverroad
- 1980 1000LTD B4
Re: GS1100 swingarm
26 Jan 2010 06:58
OK, I just jumped on this swingarm bandwagon. Just bought one from fellow KZR member Madkaw1200. But it still needs a lot of polishing and cleaning up.
Anyway, in looking at the pivot bearings, I'm missing one roller from one of the cages, so I'm going to order some new ones from Z1E.
But before I start beating on the thing, are they hard to drift out, or would this be better done by someone with a press?
I also noticed there is no grease zerk on the thing, so I guess I need to pack the entire tube full of grease and hope for the best. From the pics above, I take it we're not all that worried about rubber seals on the ends of the pivot bolt tube?
- TerryK
Re: GS1100 swingarm
26 Jan 2010 09:28
riverroad wrote:
Better to have them pressed out so as not to damage the aluminum.
Grease fittings are for heavy equipment, not motorcycles!
Just pack the bearings normally, no need to load the whole tube with grease. As far as the pivot seals, I wouldn't leave them out if I didn't want to have rusty bearings.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
- otakar
Re: GS1100 swingarm
26 Jan 2010 09:58
I agree, the end seas are critical. I would make sure you have them on.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- riverroad
- 1980 1000LTD B4
Re: GS1100 swingarm
26 Jan 2010 12:25
Thanks guys. New bearing and seals it is. According to drawings of both the GS1100 KZ1000 swingarms the end seals are called caps. Are they rubber, steel or plastic or what?
And will the bearing to bolt sleeves from my Kaw fit the Suzuki swingarm?
- TerryK
Re: GS1100 swingarm
26 Jan 2010 12:29
riverroad wrote:
You'll have to use the Suzuki caps/seals. I'm not sure about the sleeves as I have a gixxer arm on mine, but I had to machine inserts to make the Suz sleeves the proper inside diameter for the Kawasaki bolt.
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
- doped304
Re: GS1100 swingarm
30 Jan 2010 07:48
Good info so far guys but I have a GS related swingarm. I got a GS swingarm that came off a KZ1000 that did the swap. I am putting it on my 78 KZ650. It looks like I have all the required spacers and correct axle but I am confused on the correct bearings. I understand I need the 1000 20mm wheel bearings but when I go to order them there are to many options. Which wheel bearings do i need? I am running mags if that matters.
