Can't loosen brake rotor bolts!!!!
- clutch
- I wish I had a tad more patience to do it better!
07 Jan 2010 18:05
Hey guys,
I am swapping out the rear wheel on my 82 kz 750 e3 for a 16" wheel (going custom cruiser style with the bike). I have been trying all day to loosen the allen bolts that hold the rotor on to put it on the "new" wheel, but I can't get them to budge at all! Does anyone have any tricks for getting these boogers off?
Thanks,
Clutch
Thanks,
Clutch
Southern Maryland, USA
1980 KZ250 LTD (traded, but still missed)
1982 KZ750 E3 (Cafe Project) (Dyna-S, Dyna Coils, V&H 4-1, K&N Pods, 6 Sigma Jet Kit, Acewell Computer, Woodcraft Clip-ons, Custom Rewire)
1966 A1 Samurai (Restoration Project)
Wish List:
KZ1000 P (For a "touring" bike)
Z1 (need I say more?)
Wish List:
- cuskaw74
Re: Can't loosen brake rotor bolts!!!!
07 Jan 2010 18:18 - 07 Jan 2010 18:18
I usually start with giving them a good smack with a hammer, if that doesn't work try heating them with a propane torch.
74 z1900 (in progress again)
74 z1900 (parts Bike)
75 Moto Guzzi v1000 convert
Asheville, NC
www.rockstarmarble.com
Asheville, NC
Last edit: 07 Jan 2010 18:18 by cuskaw74.
- Kawickrice
07 Jan 2010 18:23
Sounds like you need some leverage. Can you get a small piece of pipe on the allen wrench to extend the leverage?
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- clutch
07 Jan 2010 18:28
Kawickrice wrote:
That's actually what I tried after soaking them in some WD-40 hoping to loosen up the crud holding them tight. With the extension, I just felt like I was going to snap my allen key in two pieces!
~Clutch
~Clutch
Wish List:
Wish List:
- MFolks
07 Jan 2010 19:19
I found that PB Blaster or "Liquid Wrench" to be good for loosening up stuck bolts. Heat the stubborn bolts up with a torch and then (with the torch shut off) apply the penetrating oil after it cools for a bit.
The stuck bolts then should be able to be removed.
When re-assembling the bolts, apply some of the silver anti-seize so they can be removed in the future. A little goes a long way, so it only needs to be applied on a few beginning threads of the bolts.
- switch
- 1981 KZ1000m CSR
07 Jan 2010 22:58 - 07 Jan 2010 23:00
Try this:
www.kanolabs.com
We use their "Kroil" in the marine industry. Also an impact driver might help.
www.kanolabs.com
1981 KZ1000 M1 CSR
2004 Vulcan 1500 Classic (gone)
You do not have to believe everything you think!
Last edit: 07 Jan 2010 23:00 by switch.
- clutch
07 Jan 2010 23:26
switch wrote:
I was thinking about trying to find some way to use my impact wrench, but just have regular, every-day allen keys....
Wish List:
Wish List:
- pgboyd
08 Jan 2010 04:00
You might consider getting some allen head sockets and try removing with a socket wrench or air impact driver. I would definitely agree with smacking them first with a hammer in case someone put blue locktite on them in the past.
Phil
Phil
Phil Boyd
Northern Virginia USA
1995 KZ1000P Police Bike
- fixer5000
08 Jan 2010 05:00
cut a pc of your allen wrench and put it in a regular socket...hacksaw works but a dremel or die grinders much quicker
1978 kz650b pretty much stock
massachusetts
massachusetts
- JMKZHI
08 Jan 2010 06:40 - 08 Jan 2010 06:41
Last edit: 08 Jan 2010 06:41 by JMKZHI.
- clutch
08 Jan 2010 10:05
JMKZHI wrote:
It's all about being more comfortable on rides! (Plus I'm getting too old to be getting tickets all the darn time. LOL!)
Wish List:
Wish List:
- RonKZ650
08 Jan 2010 12:38
Use air tools but only air impact allens. The bolts are stubborn, using cheap tools you'll probably round off the allen heads before they come loose.
