LTD,Spectre and CSR
  • chonus
  • chonus's Avatar
Re: LTD,Spectre and CSR
08 Aug 2012 19:23
#541437
was there any difference between frames? i have an 82 kz1000 and i think its a csr (hard to tell since i bought it completely taken apart) but it has those large plates for pass foot pegs, mag wheels, and dumb handlebars. but basically i wanna make it look like the older 1000's that have that stylish rear fairing "duck-tailed" i guess. any input would be awesome
-Dave
'82 kz305 lil bob
'82 kz1000 streetfighter project
'80 kz750/4 LTD
'02 kx125
  • martin_csr
  • martin_csr's Avatar
09 Aug 2012 10:27 - 22 Jan 2013 21:05
#541538
never mind
Last edit: 22 Jan 2013 21:05 by martin_csr.
  • apbling
  • apbling's Avatar
09 Aug 2012 10:47
#541539
I get a kick out of the LTD. If it is truly limited, that means to me limited edition, aka, offered for a short time or in limited numbers... But, for every 10 KZ's I see, 9.6 of them are LTD's. I've seen a handful of spectres and a couple CSR's, but I rarely every see a standard or GPz around Wisconsin and Iowa.
  • csrjoe
  • csrjoe's Avatar
18 Sep 2012 22:17
#549581
dont know about you staff sergent, but your meaning of spoke wheels r rims with those chrome stems from rim to axle, my 83 csr has mag wheels. the Roadster that harley came out with, was always a favorite of mine from hardley dickerson. oops, starting to go down hill.
  • grant_stl
  • grant_stl's Avatar
20 Sep 2012 15:46
#549908
Do you know if the 83 KZ1100 A2 and the Spectre D2 share the same frame? I have both. the A2 is not running and is my next project. From what I can tell every part of the base frame is exactly the same and the components interchange. I cannot tell if the steering head is different but I do know that the forks are different (obviously not part of the frame though).
83 KZ1100 Spectre, St. Louis elevation 500 ft.
K&N RU-0984 (pods)
4 into 1 Header
Pilots 40 1.5 turns out
Mains 135 (cylinders 2 and 3)
Mains 132.5 (cylinders 1 and 4)
Needles 5ix11 set on clip 2
  • martin_csr
20 Sep 2012 17:28 - 23 Feb 2013 16:01
#549928
CSR has no meaning. Matchless applied the term to various models, including a G12 CSR (650cc). There was a Kawasaki 650-CSR.
Last edit: 23 Feb 2013 16:01 by martin_csr.
  • grant_stl
22 Sep 2012 19:52
#550303
Thanks for the info.
K&N RU-0984 (pods)
4 into 1 Header
