my rear brake mstrcyldr piston is stuck kz1000 '78
- newOld_kz1000
- FlimFlamFlibbityFlee !! BoonFryedShickaMuhZee !!
Re: my rear brake mstrcyldr piston is stuck kz1000 '78
18 Dec 2009 08:53
Well, I'm somewhat new to air compressors and have not seen a rubber tip like that! Looks like it threads right on to the end of the gun, thanks I should be able to find one today.
1978 kz1000 A2 with Kerker
1980 Z1 Classic with Kerker
- Kawboy74
18 Dec 2009 18:07
Try the grease gun fitting and you won't have to try and grab anything risking damage to the piston! This also works the same on calipers as it is the same size. I almost wore a caliper piston and the thought of it landing on top of my tank in the shop almost made me mess myself.This also saves soaking time, you know, that rare commodity that could be used for other things. Good luck David
1974 Z1A As original as I could get it
'88 ZX750R braided lines, mostly original
KZ1000 project on the bench
Burlington,Ontario,Canada
