Brake reservoir' gasket leaks, alternatives?
  • Qdude
  • Qdude's Avatar Topic Author
  • It is all good.
Re: Brake reservoir' gasket leaks, alternatives?
05 Dec 2009 12:57 - 05 Dec 2009 13:00
#337630
Hey Patton, how are things?:)
Oddly enough, the O-ring I am speaking of, is NOT in the exploded view. I guess they never expected anyone to remove the plastic cup from the aluminum base. I wanted to get the crud out from under the plastic, so I pulled it.
Plummen you guessed right!!
gane, no prob man!
I will be looking for signs that the rubber O-ring is failing. Discoloration of the fluid, leaks around the plastic cup, or flames...
So far so good!!
P.S. Just read your post. We were typing at the same time.
77 KZ 650 C1.
77 KZ 650 C1.
Last edit: 05 Dec 2009 13:00 by Qdude.
