zx10 m/c and brake lines question
  • 9am53
  • 9am53's Avatar Topic Author
  • homebrew, and some bbq
20 Oct 2009 05:33
#328553
So I picked up a m/c from an '08 ZX10 to replace my bulbous LTD m/c to make room on my drag bars. THis unit looks really amazing, and it is literally 1/3 the width, maybe less!
The banjo bolt happens to be a double banjo, SO I was thinking that I would run my 2 ss brake lines directly from the m/c down to the calipers and avoid the distribution block. I thought that would look kinda trick (more shiney ss), and maybe soften the braking a bit with the extra volume of brake fluid to move. Can I rig the double banjo up to the m/c like this with the 2 brake lines?
  • timebomb33
  • timebomb33's Avatar
Re: zx10 m/c and brake lines question
20 Oct 2009 08:22
#328569
it should work
I THINK MY POWERBAND BROKE
  • hugo
  • hugo's Avatar
  • '92 Zephyr 750
20 Oct 2009 10:32
#328583
Yes, it works. I have mine like that. It was a HEL kit. I understand that racing motorcycles hook it up like that. Theoretically, it makes it easier to eliminate air because the paths the fluid follows is less convoluted, w/out distribution block and extra banjos. However, I don't like the unsymetrical looks of lines.
  • 9am53
20 Oct 2009 10:45
#328586
If you don't mind my asking, do you have any pics of your brake line setup? The way I imagine it it will look good, but seeing it actually hooked up might change my mind
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
20 Oct 2009 14:48
#328618
it doesnt matter how u run the lines, u can run 1 line down to 1 cal and then a jumper over the the other cal if u like.Which ever is most apealing to YOUR eye. u can tie your brake wires into the zx10 brake swith at the master lever as well.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • 9am53
20 Oct 2009 18:07
#328646
I asked about doing the jumper over the fender a couple weeks ago and I got the impression that his would lead to uneven braking and or premature brake pad wear on one side...I do like the look of OMR's setup but I think maybe having both lines coming from the top would look beefy. As far as the brake light switch is concerned the old switch wires hooked up to the control on the handlebar via some weird ass connection, (the clutch switch is the same connection) I didn't know how to remove it so I got mad and hulked up and ripped it out. How can I remove these connections? would the 2 wires just connect to the 2 prongs on the new brake lever?
  • kztee
  • kztee's Avatar
  • TeeRoy
20 Oct 2009 18:11
#328647
When I hooked up my new m/c thats all I did. Hooked up the twos wires to the two prongs via some slip on connectors
1977 KZ 1000A - Currently rebuilding
1980 KZ 750 LTD - Mostly stock daily rider
1979 KZ 1000 LTD - Parts bike and/or future project
1979 KZ 1000 ST
1980 GS 750 L
2003 ZRX 1200 R
  • thompsonmx100
  • thompsonmx100's Avatar
20 Oct 2009 18:38
#328665
you can hook up your brake lines either way two or with a jumper shouldn't cause any uneven wear. lots of bikes come from the factory like that. and as far as the switch goes just hook the two wires up using female connectors the switch just closes when you apply the brakes. I think the one brake line with a jumper would be cleaner. If you look up OMRs bike he did his both ways. actually I think he did his all three ways. jumper, two lines and distribution block.
2006 gs 500 streetfighter
1982 gpz750 breathed on wreck
1985 gpz750
Kz 650
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
21 Oct 2009 11:17 - 21 Oct 2009 11:26
#328749
I tried all 3 ways myself. it just comes down to personal preference.
the issue I came across is simply trying to keep the lines orderly. i still need to find a hose clamp that i can attach to my fender on each side. i currently have the lines jury-rigged .
i have upside down forks and i need to keep the lines away from the pinch point, of the fender and forks.
any one have any idea's? i'm sure there are some nice factory brake line rings that tie into a fender, out there some were?
here is a pic when i had the 3 lines and a splitter. i would have prefured to run the lines behind the forks, but i allready had these lines, and they were a little long.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 21 Oct 2009 11:26 by mark1122.
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
21 Oct 2009 11:32
#328758
here is another.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • thompsonmx100
21 Oct 2009 15:42
#328786
not to thread jack but where did you get that front brake lever mark?
1985 gpz750
Kz 650
  • 9am53
21 Oct 2009 16:11
#328791
interesting, now I really don't know...
