Who goofed: Me or the Tireman?
  • ltdrider
  • ltdrider's Avatar
Re: Who goofed: Me or the Tireman?
19 Mar 2006 07:29
#32469
Skipper:
I'm trying to attach a picture of the Rear Hub Assembyl from the LTD Supplement.
Here goes....
'76 KZ900 LTD (Blaze)
'96 Voyager XII (Dark Star)
Greensboro, NC
  • skippr76KZ
  • skippr76KZ's Avatar Topic Author
19 Mar 2006 07:37
#32474
LTDRider to the rescue! Thanks for the hub assembly scan. That's a much clearer representation than the Kaw on-line diagrams. It's what I used to have in my now missing supplement book. No bike shops open today to reverse that tire so, I'll work on handlebar controls and other stuff. So LTDRider, is the Morris wheel 8 holes on 1-side and 6 on the other just an LTD thing? Must be because of the rear disk brake. At least for that year and above?
1976 KZ900LTD Fully Restored
2000 Vulcan FI Classic
1998 Ducati ST2, Gone
  • steell
  • steell's Avatar
19 Mar 2006 07:52
#32476
Interesting, must be a difference between the "Made for Kawasaki" Morris Mags and the Aftermarket ones.
Here is a pic of the Morris Mag off my 79 twin, the difference is obvious :)
  • dan76kz900
  • dan76kz900's Avatar
19 Mar 2006 09:39
#32497
skippr76KZ: a little bit off topic.. but your brake rotors are looking brand new ! Did you have them turned down or are they new ? I havent figured out if its possible to get bike rotors turned down..
  • ltdrider
  • ltdrider's Avatar
19 Mar 2006 10:43
#32518
Skipper:
Looks like 8 bolts hold the Coupling Housing (item 20 on the scaned diagram) to the wheel. So the wheel has 8 tapped holes on the sprocket side.
The disc is held to the disc adapter (item 23) with 6 bolts. But I can't tell if the wheel is drilled with 6 or 8 holes on the disc side, and the disc adapter 'compensates'. I'm not sure, but it may not be possible to put the disc/sprocket on the 'wrong side'.
I laughed when I saw that you're building the bike in your house. You have an understanding wife!:lol:
Greensboro, NC
  • skippr76KZ
19 Mar 2006 12:30
#32547
Dan76kz900, thanks to an archive posting last year from "Oldcoldankels" - check out this forum:
kzrider.com/forum/viewthread.php?tid=19338
I took my rotors to a local engine machine shop that had a "flywheel" re-surfacer or re-facer. A common thing for them. My rotors were well within speck. He charged me $20 bucks apiece. LTDRider - Thanks again. My Morris wheel has 8 tapped holes on one side, (sprocket) and 6 tapped holes on the other, (disk).
  • dan76kz900
19 Mar 2006 12:48
#32557
skippr76KZ: Thanks for the link !
