Drive Chain tensioners
- PLUMMEN
Re: Drive Chain tensioners
15 Sep 2009 18:23
mark1122 wrote:
modify a brake pedal spring?531blackbanshee wrote:mark,the atv dragracers have to use spring loaded tensioners to keep from throwing the chains on the stretched out swingarm bikes.they are typically for 520 chains but could be modified or have a custom roller built.
remember the bottom of the chain is where the slack is,the top run is the one with the torque on it.
hth,
p.s. here is the link
www.g-forcepowersports.com/ztrchte.html
This would be sooooo easy to make.all i need to find is the spring.
any ideas are welcome.
- kano
- Not Another Bloody Limey!
15 Sep 2009 18:38 - 15 Sep 2009 18:44
i dunnno bro i have a tenancy to over engineer things
plus as a after thought
it will be easier to get a hydrolic set up to give just the right amount of tension compared to getting a spring to supply it.
plus a spring looses it tension over time, hydrolic's don't if properly maintained.
worse thing your strip the teeth off your sprocket giving it the beans!
Last edit: 15 Sep 2009 18:44 by kano.
- mark1122
- Keep twisting it
15 Sep 2009 18:49
Nothing wrong with over eng Kano. but this seems simple enough to try , if i can find a spring.
Good thought there Plumman. i just pulled 1 out of my spare parts box. that is the right idea, just a little large in the mid. i may be able to do something with it if i cant find a better 1.
Thanks.
Thanks.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- moneypit
15 Sep 2009 20:34
Try Grainger 8 pages of torsion springs
www.grainger.com/Grainger/wwg/productIndex.shtml
2-76 kz900
St Paul MN
St Paul MN
