77 KZ650 Front Brake Squeak
- ozone
08 Aug 2009 10:16
I recently replaced the original front brake pads with new IBC pads. I've put 250 miles on them and it still squeaks. If I grab the lever hard there's no squeak. If I'm applying a tad of front brake it squeaks REALLY loud. I don't even touch the front brake riding through the neighborhood at night. It's that loud. What is causing the squeak? The rotor is not groved and looks to be in great shape.
- Kawickrice
Re: 77 KZ650 Front Brake Squeak
08 Aug 2009 10:39 - 08 Aug 2009 10:42
Did you use the little snap on clip behind the pad when you replaced the brakes? I see you are in St. Pete, I am just across the bridge, USF area
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
Last edit: 08 Aug 2009 10:42 by Kawickrice.
- ozone
08 Aug 2009 13:01 - 08 Aug 2009 13:03
Here's a photo of the old pad that has what iassume is the clip. The other pad is threaded and has a screw attaching it to the "backing plate"?
So was I suppose to pry this metal piece off and then glue it to the inside of the new pad? That flat thin piece was pressed on top of it.
Last edit: 08 Aug 2009 13:03 by ozone.
- 550A2
- keep the shiny side up
08 Aug 2009 13:10 - 08 Aug 2009 13:15
put some anti squeal brake stuff on the backing plate.
also, there sometimes you can do a brake pad break in procedure. the 30 30 30 trick. Get going up to 30mph and slam on the brakes, wait 30 seconds and do it again approx 30 times.
Im in auto tech and thats what they say to do when new brake pads are squeaky, which is very common. It usally does the trick by removing any of the rotor glazing that was caused by the old pad.
good luck man.
Luke
good luck man.
Luke
82 Honda ATC 200-sold
82 Yamaha Virago 920-sold
82 Yamaha YZ250j-kept
80 Suzuki GS 550-sold
82 Kawasaki KZ550 A2-ride all the time
79 Kawasaki KZ650 C-sold
73 Kawasaki Z1 900E-paid $200, sold $6000
86 Yamaha Radian YX600-new project
Last edit: 08 Aug 2009 13:15 by 550A2.
- Kawickrice
08 Aug 2009 13:31
ozone wrote:
I don't know for sure if it will fix it but I always transfer it to the new ones and have not had a problem. I never had to glue them though. You might check the rotor for any loose bolts which would let it vibrate when braking also.
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- bountyhunter
08 Aug 2009 14:46 - 08 Aug 2009 14:49
ozone wrote:
The factory pads on mine have the anti-squeal shims built into them, the aftermarkets don't and they squeal. My cure for squealing brakes was to buy a helmet with better sound insulation....... that and the natural deafness that comes with old age.:laugh:
As you apply pressure, the pad vibrates against the face of the rotor and the rotor acts like a loudspeaker (vibration to sound transducer).I recently replaced the original front brake pads with new IBC pads. I've put 250 miles on them and it still squeaks. If I grab the lever hard there's no squeak. If I'm applying a tad of front brake it squeaks REALLY loud. I don't even touch the front brake riding through the neighborhood at night. It's that loud. What is causing the squeak?
Last edit: 08 Aug 2009 14:49 by bountyhunter.
- bountyhunter
08 Aug 2009 14:48
ozone wrote:
The small metal piece is the anti-squeal shim.
- toadson
08 Aug 2009 22:24
I've been having the same problem on my KZ1000, except the squeak isn't extremely loud like yours. If I just barely squeeze the brake handle, it will squeak every time. I wonder if using some anti-seize behind the brake pad would help?
79 KZ1000 LTD. Mikuni VM26 w/ accelerator pump. 4 into 1 header. Stock intake setup. GS1100 Swingarm, My swap thread:
kzrider.com/index.php?option=com_kunena&...d=5&id=210872#210872
- JMKZHI
09 Aug 2009 08:00
Are oem pads available for your bikes?
The aftermarket squeal problem has been mentioned before, and others have stated that the fix is to get genuine Kawasaki brake pads.
- RonKZ650
09 Aug 2009 18:18
All aftermarket brakes are garbage. Look on ebay ect and you can get Kawasaki pads for a good price.
- rstnick
10 Aug 2009 08:33
Loud brakes save lives.
My 650 squeels too.
My 650 squeels too.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- 9am53
- homebrew, and some bbq
10 Aug 2009 08:41
It's funny this post is up now, I was just going to make this identical post today myself. Had my pads changed and they squeal when I am slowly apporaching red lights, but not under heavy braking...
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
'71 CB350
