having issues with my chain
  • OregonMatt
  • OregonMatt's Avatar Topic Author
28 Jun 2009 20:14
#302890
so my chain doesn't seem to sitting in the rear sprocket. I have made sure that the wheel is adjusted and straight. The wheel will turn and the chain will go out of the teeth. then it will pop back in. the pictures show the chain as it sits in the sprocket, and when it doesn't any suggestions would be appreciated
1976 kz 900
  • PLUMMEN
  • PLUMMEN's Avatar
Re: having issues with my chain
28 Jun 2009 20:17
#302894
chain is probably stretched too much,new sprockets and chain should fix that problem :(
  • trianglelaguna
  • trianglelaguna's Avatar
28 Jun 2009 20:22
#302898
as long as it is aligned with the front sprocket and the spacers and everything is in order on the axle then...the chain has a stretched spot....does it have a center stand so you can free spin it front and backwards in the air in neutral?PLUMMEN wrote:
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
28 Jun 2009 20:36
#302904
Can you take a picture of the sprocket from the side view? Someone may be able to tell you if the sprocket appears to be worn beyond its practical limit. Ed
  • Old Man Rock
  • Old Man Rock's Avatar
29 Jun 2009 04:38
#302959
1976 KZ900 OEM chain/sprockets are a 630 pitch...
Hard to say in review of the image but it seems the rollers don't fit between the sprocket teeth at all. Even in a worn state (sprocket teeth) the rollers should drop in between...
Measure your sprocket & chain pitches...
Via Z1:
The first number of the chain designates the chain pitch and represents the distance between each pin in eighths (1/8) of an inch.
630 chain is 3/4" pitch (or think of it as 6/8"), 530 chain is 5/8" pitch - so if you are not sure what size chain you have on your bike, just measure the pin-to-pin distance.
The second two numbers show the width of the roller section of the chain in eighth's of an inch with an assumed decimal point between the numbers. So 630 chain is 3/8" wide and 525 chain is 5/16" wide (2.5 eighths).
520 5/8 inch pitch, 1/4 inch wide
525 5/8 inch pitch, 5/16 inch wide
530 5/8 inch pitch, 3/8 inch wide
630 3/4 inch pitch, 3/8 inch wide
Plummen hit it on the nose, new sprocket and chain... ;)
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
29 Jun 2009 04:58 - 29 Jun 2009 04:58
#302961
Last edit: 29 Jun 2009 04:58 by Patton.
  • OregonMatt
29 Jun 2009 06:23
#302968
I can get that pic, but it sounds like a new chain and sprockets are in order. That's what I thought. any suggestions on what sprockets work best
1976 kz 900
  • trianglelaguna
29 Jun 2009 07:47
#302991
a well maintained middle priced set up will out last a non mantained pricey set by about 10 times as long...that said ...if you get a name brand set and are not made of money or gonna ride a hundered miles a day all year....then a basic heavy duty chain is fine.....lube adjust whatever you get as often as you can and a decent chain for 65-85- and about 20 front sproc and 35 rear is not out of a guys financial reach.....it'll work well for a long long time...replace all at the same time with new......good luck......
1976 KZ900
2003 ZX12R
2007 FZ1000
  • trianglelaguna
29 Jun 2009 07:54
#302993
i've been watching some basic chains online for another bike project i have and dont wanna spend too much on for now.... and if you search "630 chain" on the e-bay site....you will see some D.I.D brand chains for as low as 49 i think.....the same brand goes past 100 depending on the class of chain......check your model for exact sprocket teeth counts and how many links your chain has then double check and see if thats what you have now on there........i want to go one tooth bigger in front next time on my kz900...i'm told this helps from trying to shift into the phantom kz 6th gear on the freeway.....good luck
1976 KZ900
2003 ZX12R
2007 FZ1000
  • OKC_Kent
  • OKC_Kent's Avatar
29 Jun 2009 08:13
#302995
I'll chime in and say 'Me too", something does look funny to me in that picture.
I bought a RK x-ring chain from Z1Enterprises two years ago and it is the best chain I ever had on a bike. It has 23,000 miles on it and I am at the second mark on the adjuster. This chain took two adjustments in the first 700 miles and has had TWO adjustments since, unbelievable but true. I lube it every 200-300 miles.
Prior to this chain I had a JC WHitney regular chain, NON oring style. With the same lube schedule I got 15,000 out of it.
Cashion, OK
78 KZ650 B2 85,000+ miles
29 Jun 2009 08:27 - 29 Jun 2009 08:29
#302998
Would recommend these offerings from Z1E:
rear sprocket
countershaft sprocket
0-ring drive chain
Haven't yet tried the xw-ring drive chain, but will likely do so when replacing the existing 0-ring version.
xw-ring drive chain
With a larger countershaft sprocket, expect noticeable decrease in acceleration from stop or crawl, same attainable top speed, and same mpg, but with a lower more relaxed cruising rpm. Akin to swapping gears 1~5 for gears 2~6.
Remember the buds you could out-accelerate in friendly drags? Becomes a fond past memory with the larger countershaft sprocket and watching them pull away! :laugh:
Good Luck! :)
Last edit: 29 Jun 2009 08:29 by Patton.
  • OregonMatt
29 Jun 2009 15:16
#303093
Thanks for the advice, I have said it before, and will say it again, this site is an awesome resource
1976 kz 900
