re-using head bearings
  • steell
  • steell's Avatar
Re: re-using head bearings
11 Mar 2006 18:56
#30196
OKC_Kent wrote:
My factory manual has 19 top, 20 bottom. They are 1/4". When I replaced mine for tapered I noticed the bottom race was dented from the balls. It had a small split starting too.
Yeah, those wheelies will do that :evil: :evil:
  • xstreamcanadian
  • xstreamcanadian's Avatar Topic Author
12 Mar 2006 17:09
#30435
thanks guys, I got it all back together, filled to the brim with bearing grease. It is smooth as glass. the races appeared to be fine. I did notice that when I tighten up the BIG nut on top of the triple tree she got to feel a little chunky, so i backed it off until it felt smooth. Is there something I should know here or did I make the right call.
  • wireman
  • wireman's Avatar
  • Visitor
12 Mar 2006 17:13
#30437
if you mean the round nut with holes for spanner wrench you did fine.do not overtighten or you will put flat spots in bearings over time.;) goodluck,happy wrenching!
  • xstreamcanadian
12 Mar 2006 18:03
#30447
yup that would be the one. I went habd tight and then a few taps with a screwdriver and small hammer.... seems ok. The stripped down and repainted triple looks awesome. IMHO
