Anyone use these bar end mirrors?
- fordtruck
Re: Anyone use these bar end mirrors?
22 May 2009 16:10
mtkawboy wrote:
Oh man that's funny! It probably wasn't to you at the time though! I've gotten used to hanging my helmet over the throttle grip when I park the bike. After I put the bar end mirrors on I almost did it again. Now I need to find a new spot to hang it other than the helmet lock.
Tried a set of them on an old Norton I had. I found them an excellent way to remove one of those pesky $300 remote control mirrors on your car. You learn that what used to fit thru a certain space no longer does when you come zipping into the driveway
'77 KZ1000-MTC 1075 kit. Stage 1 port
22 May 2009 19:04 - 22 May 2009 19:07
fordtruck wrote:
One option could be a decorative helmet mount stud that fits into the unused mirror hole, such as this item at JC Whitney.
Helmet holder stud
Good Luck!
...gotten used to hanging my helmet over the throttle grip when I park the bike. After I put the bar end mirrors on I almost did it again. Now I need to find a new spot to hang it other than the helmet lock.
Helmet holder stud
Good Luck!
Last edit: 22 May 2009 19:07 by Patton.
- fordtruck
22 May 2009 23:13
Thanks Patton. I looked these up on JcWhitney and they are a 6mm bolt. The mirror mount is 10mm. I think I've seen these before and you use them as a replacement for your clutch or brake lever pivot bolts.
23 May 2009 00:58
fordtruck wrote:
You're right.
And thanks for clearing a foggy memory.
I don't see anything similar for 10mm threads.
Found listings for some of the more elaborate adjustable mounting hardware for such things as GPS, camera, etc., available in 10mm. But not a simple 10mm decorative post mount.
Perhaps a chrome shouldered fat hex head 10mm bolt of appropriate length would look nice and serve okay for a helmet post.
Foggy memory also recalls caution about likely damage to helmet lining from hanging it on a small post. So I just continue the old fashioned way of attaching helmet D-ring to the oem underseat bike hook, or hanging it on the oem mirror.
Am thinking bar-end mirror fans sometimes fill the unused mirror holes with short bolts or plugs (plastic or rubber) for a more finished appearance.
Good Luck!
You're right.
Good Luck!
- da_wun
23 May 2009 08:01
i got a similar pair, except mine has the carbon fiber sticker on it (looks cool
If you don't mind waiting like 2 weeks-ish, try these,
cgi.ebay.com/ebaymotors/Bar-End-Mirrors-...fPartsQ5fAccessories
Haven't had the chance to try em out yet, but they look good, and the expanding part inside the bar ends worked (forgot the name).
Bare Metal 1980 KZ750H (no longer burgundy)
West-Island, Montreal
- The Garbone
- User is Currently waiting for his bailout check..
24 May 2009 06:06
Uh oh, since I just got my machine running and on the road for the first time yesterday I realized that I need mirrors..
Tried to install the exact mirrors in the first post on the driver side grip. The will not fit inside the bar, as the bar tube walls are to thick... Fought with it for a bit before giving it up.. Might have to take the mirrors of my Enfield for my KZ since they have a better insert setup.
I would not buy those because of the dodgy inserts..
Gary
Gary
2007 Royal Enfield Iron
1979 KZ650 & Hack
1949 Ford 8n
1979 KZ650 & Hack
1949 Ford 8n
- donthekawguy
24 May 2009 23:25
I always use the kind with rubber mounts that go in the end of the bars. I got a set with the metal and they fell out. :laugh:
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- joshmickelson
12 Jun 2009 08:10
sorry for bumping an old thread. I just got some of these, and had a little trouble installing them. The larger of the metal mounts is just a TAD too big to fit on the end of my bars. Should I just use some pliers, or am I doing something wrong?
Here is what I got:
cgi.ebay.com/ebaymotors/YAMAHA-KAWASAKI-...fPartsQ5fAccessories
Here is what I got:
'78 KZ650
- kztee
- TeeRoy
12 Jun 2009 08:43
I just got these last week and so far I love them...
1977 KZ 1000A - Currently rebuilding
1980 KZ 750 LTD - Mostly stock daily rider
1979 KZ 1000 LTD - Parts bike and/or future project
1979 KZ 1000 ST
1980 GS 750 L
2003 ZRX 1200 R
1979 KZ 1000 ST
1980 GS 750 L
2003 ZRX 1200 R
- joshmickelson
12 Jun 2009 08:53
did they fit right into the end, or did you have to mess with it more?
'78 KZ650
- kztee
- TeeRoy
12 Jun 2009 08:55
Pulled them out of the box and put the right in to the bar end. Tightened the allen bolt and rode off into the sunset. Very simple.
1979 KZ 1000 ST
1980 GS 750 L
2003 ZRX 1200 R
1979 KZ 1000 ST
1980 GS 750 L
2003 ZRX 1200 R
- joshmickelson
12 Jun 2009 09:28
ok cool, that how I thought it should be. I am wondering if my bar ends are a little smaller than they were originally.
thanks!
thanks!
'78 KZ650
