DOT5
- athlonwirez
DOT5
19 May 2009 10:32
I'm thinking about converting to DOT5. Is it possible to flush the old fluid out(DOT3) with DOT5 until there is only DOT5 in the system? Or would I need to replace hoses and seals? I will be rebuilding the master cylinder anyway.
1978 LTD Partial Restoration in Process. (Do not have orginal exhaust)
- RonKZ650
Re: DOT5
19 May 2009 10:53
Sure you can do that. I'm sure there will be argument "they don't mix". The truth is you can pump most the dot3 out until the master cylinder is near empty, add dot5, repeat until you're sure only dot5 is being pumped out. I put dot5 in all my old Kawasakis when dot5 was first seen. When was that? I guess the mid 80s. I've never had one brake problem using dot5.
- athlonwirez
Re: DOT5
19 May 2009 11:55
Thanks Ron!
- otakar
Re: DOT5
19 May 2009 11:59
I used to run DOT 5 years ago because I thought that being silicone would protect things better. The problem is on the contrary. Everything I put DOT 5 into corroded. The problem with DOT 5 is that it will NOT absorb moisture. This will cause the moisture to settle out and cause massive corrosion in the places it settles. You would be much better to use DOT 4+ this fluid seams the best of both worlds.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- timebomb33
Re: DOT5
19 May 2009 12:27
even harley doesn't use it anymore they have switched back to dot4 it may be due to the fact that they have abs now i'm not sure,all i know is they switched back.
I THINK MY POWERBAND BROKE
- athlonwirez
Re: DOT5
19 May 2009 13:31
Really the only reason I'm interested is the fact it will not mess up the paint on the front master cylinder. I'm due for a rebuild, and it will need to be painted.
- PLUMMEN
Re: DOT5
19 May 2009 15:37
RonKZ650 wrote:
ditto,weve had many debates over this but ive never had problemsSure you can do that. I'm sure there will be argument "they don't mix". The truth is you can pump most the dot3 out until the master cylinder is near empty, add dot5, repeat until you're sure only dot5 is being pumped out. I put dot5 in all my old Kawasakis when dot5 was first seen. When was that? I guess the mid 80s. I've never had one brake problem using dot5.
- franknsr
Re: DOT5
19 May 2009 17:46
Same here. I rebuilt my master then flushed out the line and caliper with dot 5. Never had an issue.
Formerly CSRchopper
1991 KZ1000P
Gone but not forgotten
1986 ZG1000
1982 650 CSR -shoulda kept this one-
Lisle Illinois, USA
1991 KZ1000P
1986 ZG1000
Lisle Illinois, USA
- rstnick
Re: DOT5
19 May 2009 18:34
I had DOT5 put in front and rear when my brakes were rebuilt in the 80's.
My bike sat for 10 years from '94 ~ '04. When I got her back on the road, the brakes worked fine, no siezing or other problems.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
Re: DOT5
20 May 2009 10:55
Otakar is right. DOT5 doesn't absorb moisture so the moisture that enters the brake system will "puddle" and cause corrosion. Obviously, some folks here have used DOT5 with good results; maybe they're not in a high humidity environment, who knows. DOT5 high a very high boiling temp and is often used in racing appplications, but racers change their brake fluid often thus purging the water. It's your choice, but in my location I wouldn't risk it. If you stick with DOT 3 or 4 just be careful not to spill it on our paint. Ed
- otakar
Re: DOT5
20 May 2009 11:36
Dot 4+ is a synthetic which should not harm the paint.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- PLUMMEN
Re: DOT5
20 May 2009 15:24
just keep the trash flushed out of your system every spring with the dot5 and youll be fine
