POR-15, Kreem, boil?
  • franknsr
  • franknsr's Avatar
Re: POR-15, Kreem, boil?
26 Apr 2009 20:03
#285556
I have a buddy who went the kreme route and swore by it. This was back in the dark ages when the best way to clean the inside of a tank was a handfull if sheetmetal screws and an hour of shaking. We've come a long way baby.
Formerly CSRchopper
1991 KZ1000P
Gone but not forgotten
1986 ZG1000
1982 650 CSR -shoulda kept this one-
Lisle Illinois, USA
  • PLUMMEN
  • PLUMMEN's Avatar
26 Apr 2009 20:19
#285578
tachrev wrote:
It may be the old KREEM that was a problem, not sure if it has changed over the years.
Thats what kept me from using it.
I saw a lot of picture of it peeling off and clogging up petcocks.
thats whyi dont use it. B)
  • Old Man Rock
  • Old Man Rock's Avatar
27 Apr 2009 05:46 - 27 Apr 2009 05:47
#285630
kreem works excellent but it does have one big problem tho. follow the directions to the letter and it works awesome don't follow them and you end with trouble
Wholly crap, there's instructions?.... :blink: :huh: :dry: :woohoo: :laugh:
Yes indeed and this holds true for Kreem or Por-15 products... For that matter, holds true for paint (RON) :P , CLEARCOATS (Markk1122):P , primers, prep work etc... basically any chemical product will lead to 100% FUBAR if not used correctly.
Are some better than others, you bet but either of these two products will work just fine...
ORM
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Last edit: 27 Apr 2009 05:47 by Old Man Rock.
  • violentvintagecycles
  • violentvintagecycles's Avatar Topic Author
27 Apr 2009 10:33
#285687
Ordered the POR-15, should be here anyday. I have no holes in the tank, thankfully, so i might just leave it at the acid treatment. Main objective is a clean tank, not necassarily coated, no? See how bad it is, see if the acid doesn't make a hole.. Thanks for the input
