Angle on rear wheel seems weird
- wireman
Re: Angle on rear wheel seems weird
05 Mar 2006 16:41
look how close the wheel is to left shock compared to right shock,i still think its the spacers.
- donthekawguy
05 Mar 2006 18:07
It looks off-check your spacers.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- loudhvx
05 Mar 2006 22:33
wireman wrote:
Anything is possible, but, in my opinion, I think the left arm of the swingarm is lower than the right (but the photo is deceiving because the whole bike may be leaning right slightly). This causes the top of the wheel to tilt toward the left shock. But look at the wheel adjusters. The tire is almost centered between them.
This is the most common fault I found on the few swingarms I've straightened. But there are other things that can cause this too. It can be the main frame as well. It's hard to say until you take everything apart and throw it onto a layout table.
Post edited by: loudhvx, at: 2006/03/06 01:47
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- Snakebyte
06 Mar 2006 03:43
loudhvx wrote:
Look at the chain relative to the engine and wheel. The spacing is definatly off.
wireman wrote:look how close the wheel is to left shock compared to right shock,i still think its the spacers.
This is the most common fault I found on the few swingarms I've straightened. But there are other things that can cause this too. It can be the main frame as well. It's hard to say until you take everything apart and throw it onto a layout table.<br><br>Post edited by: loudhvx, at: 2006/03/06 01:47
- wireman
06 Mar 2006 05:42
hold the phone gang look at the center line of the brase on back of frame where tailpiece goes compared to backbone of frame:whistle:
- loudhvx
06 Mar 2006 11:26
Yes, it does look a lot like the rear of the main frame is whacked.
1981 KZ550 D1 gpz.
Other links.
Other links.
- ran429
- Master of FREE rides!
06 Mar 2006 15:58
I am coming down to it being the swing arm, when I look at my other one mounted on a different frame, I see them (tail ends) pointing straigh out the rear, on this one the right side is pointin inwards.
I am going to be hanging the swingarm now and see what gives afterwards.
if its a bent frame I am done with it and Parts go on ebay. :whistle: I dont have the time or tools to straighten a frame and can afford to repaint another one.
Lets just hope the new swingarm is straight this time.
I did (so sis my son in law) measur from the center of the neck to each frame rail and they were dead on. then measured from the backbone rail end to the opposite corner on the rear and they were dead on, so I looked deeper at the swingarm and seen the tail end of it pointing inwards on the caliper side (right) pointing hard left compared to the straight one on my other frame.
This Bike was down at one point, But it only scuffed up the timing cover I thought. Nothing else was marked with road rash at all on the frame, But the exhaust was skinned a little though.
Oh well, Nuff with that. Onto remounting another swingarm. Crossing my fingers.
- NOS
06 Mar 2006 15:59
Toldya
... just jking
I think that the rear frame may be twisted a bit. I had the same prob, and the frame was just off a hair.
- ran429
06 Mar 2006 16:45
Well, i just put the two swingarms I have here together, back to back end to end and stacked.
all the points match up together, ends when back to back are identical.
I cant mount my spare set because the previous ownere of that bike didnt ever take the swingarm off and grease the bearings, so they are frozen solid and rusted in place (along with Egg shaped innards) so I am S-O-L on a spare swingarm.
with the wheel off and the swingarm removed, the frame looks (to the eye) square as heck. I couldnt have the spacers flip flopped as they only go into the wheel one way.
maybe its just my eyes and comprehention is warped? But then again a few of yours would be warped also.
atleast i'm not alone in my insanity.
- ran429
06 Mar 2006 17:36
I see what the problem is I believe its "MY" fault afterall.
Look where I lifted the frame to lower it onto the motor.
Post edited by: ran429, at: 2006/03/06 21:08
- ran429
06 Mar 2006 17:39
And the result from my Bad Lifting Procedure is in this photo.
Look carful at the fishing line plum bobs I made and the center line going the length of the frame center.
