Do I need the rim locks?
  • RonKZ650
  • RonKZ650's Avatar
Re: Do I need the rim locks?
21 Feb 2009 16:34
#266884
Actually the rimlocks can be an aid against pinching the tube. If you plan where they are during your tire install, you can have one right in that sweet spot where the tube normally gets pinched :angry: and it pretty much isolates the tube from possible pinching. As to the soap/water combo, that's what I've used for near 30 yrs and never had a problem, then someone on the goldwing forums said to never use it on Honda aluminum wheels because it corrodes the aluminum and you'll get flat tires (tubeless of course). I'd changed these goldwing tires 2 or 3 times in the past using soap and water and never had a leak, but had just put new tires on like a week before I read this :S so called bull on the idea. Flat tire next time I went to ride the bike, wheel corroded. If just that guy hadn't said anything :laugh: So soap/water not recommended on aluminum. On steel, never had a problem. Might as well just get tire lube. No-mar the guys that make those nice tire change machines sell tire lube. I got some and haven't had the pleasure of using it yet, but expect it works just fine.
  • gane
  • gane's Avatar
21 Feb 2009 17:00
#266889
I run without, & fill hole w/a 6x12 countersunk screw nutted on outside.a fresh rim strip & go. makes mounting AND balancing easier. If you don't like the Idea of soap & water, baby powder is an old mxer's standby. It reduces tube chaffing and aids install. luck G
[img][/img] 1977 KZ1000A1
  • H2RICK
  • H2RICK's Avatar
  • Is this a fun bike, or what!!!
21 Feb 2009 21:25
#266973
If you have a wrecker's yard close by, go and search through their wheel racks for wheels with little push-in plugs in the rim lock holes. There are various mags made that were drilled for rim locks but the factory never installed the locks for whatever reason. Instead, they inserted these nifty little rubber plugs in the hole(s).
KZ650C2 Stock/mint. Goes by "Ace".
H2A Built from a genuine basket case. Yes,it's a hot rod.
GT550A Stock/mint. Pleasant stroker.
2006 Bandit 1200S for easy LD rapid transit
Various H2 projects in the wings.
  • OKC_Kent
  • OKC_Kent's Avatar Topic Author
22 Feb 2009 06:30
#267061
I got the tire on using just dish soap. And I put the rim locks in. My rim strip had holes for the locks from a prior change so it wasn't too difficult. But I am going to buy a tire changer, I was so achy afterwards I took two Ibuprofen and later on some Tylenol. :laugh:
Cashion, OK
78 KZ650 B2 85,000+ miles
22 Feb 2009 06:45
#267062
Congrats! You did the right thing. It makes you think twice about doing burnouts and wearing the tire out prematurely doesn't it? :laugh:
  • cnyl
  • cnyl's Avatar
22 Feb 2009 07:09
#267070
Anybody have a pic of what a rim lock looks like? :blush: I'm running tubes and would like to see what your talking about.;)
Thanks
1982 KZ1000 M2 CSR
North Port, FL
Check out my band
www.myspace.com/tukrhill
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
22 Feb 2009 07:39
#267077
Here's a pic herk posted on kz650.info.com on what the rim lock/rim stopper looks like on his 1981 kz650CSR:
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
22 Feb 2009 08:14 - 22 Feb 2009 08:15
#267089
Here's another that looks very much like the original and a site to buy them cheap (it's the 15th picture on the website).
RIMLOCK
Last edit: 22 Feb 2009 08:15 by 650ed.
  • PLUMMEN
  • PLUMMEN's Avatar
22 Feb 2009 08:27
#267093
park your bike in the garage or chain your dog to it if youre worried about your wheels being stolen!oh,those rim locks!:laugh:
  • cnyl
  • cnyl's Avatar
22 Feb 2009 17:24
#267262
Thanks rstnick and 650ed! Now i'm really confused..:blush:
Where the heck does that go?:huh: I just looked at my wheels and didn't see anything like that.
Thanks
1982 KZ1000 M2 CSR
North Port, FL
Check out my band
  • PLUMMEN
  • PLUMMEN's Avatar
22 Feb 2009 17:40
#267272
all you will see is what looks like head of bolt with a nut on it sticking through rim the rest is inside of tire when its installed B)
22 Feb 2009 18:21
#267305
cnyl,
If your rear wheel has rimlocks you will see 2 threaded stems with a nuts on them located 180 degrees apart on the rim. The pic below shows 1 rimlock and the valve stem so you can see the difference. The second rimlock is not in the picture, it's 180 degrees away from the one shown.
